Results 1 to 9 of 9
Thread: Issue with wcmatch xrefs
    2019-05
    15
    Default Issue with wcmatch xrefs
    I have some code that is meant to search through xrefs in a drawing, and if it finds one xref with particular text, I'd like to extract some other text from that same xref's name.
     (defun C:CUS-PAGE-CONFIG (/ activedocument xrefs xref psetup psize)
    	(vl-load-com)
    	(setq activedocument (vla-get-activedocument (vlax-get-Acad-Object)))
    	(setq xrefs (vla-get-blocks activedocument))
    	(vlax-for item xrefs								;looking through xrefs
    	(setq yesxref (vlax-get-property item 'isXref))
    	(if (= yesxref :vlax-true)
    	(setq xref (vlax-get-property item 'Name))
    	);if
    	);vlax-for
    	(if (wcmatch (strcase xref) "*TBLOCK*")				;if any xref matches TBLOCK then setq psize
    	(setq psize (substr xref 10 2))
    	);if
    	; ... (rest of code not important)
    It seems to work fine for when there is only one xref in the drawing, but as soon as there are more, I'm told "Error: bad argument type: stringp nil".
    Any help would be greatly appreciated.
    2010-06
    962
    Default Re: Issue with wcmatch xrefs
    Hi,
    You have the Xref matches out of the iteration circuit but even though the routine would return only the last subtracted string from the last Xref reference that might match the criteria.
    2019-05
    15
    Thanks for the response!
    Yes, so I guess my question is how should I arrange it so that the routine will look through ALL the xref names and return the one that I am searching for...
    2010-06
    962
    Quote Originally Posted by mruu88781911 View Post
    You're welcome.
    This is what I meant with my previous reply.
    (defun C:CUS-PAGE-CONFIG (/ activedocument xrefs xref psetup psize) ;
        )                                   ;if
        )                                   ;if
      )                                     ; ... (rest of code not important)
    (vl-load-com)
    2019-05
    15
    Quote Originally Posted by Tharwat View Post
    You're welcome.
        )                                   ;if
        )                                   ;if
    (vl-load-com)
    Ok so I had actually tried that as you suggested but it stopped it from working all together (multiple xrefs and SINGLE xref too).
    It's weird because it definitely makes more sense but something's preventing it from working...
    2010-06
    962
    Hi,
    I have changed the entire code beside that the routine name so please try this instead and let me know.
    NOTE: the return would be as a list if any xref name matched otherwise nil.
    (defun c:Test (/ bkn lst)
      (vlax-for item (vla-get-blocks (vla-get-activedocument (vlax-get-Acad-Object)))
        (if (and (= (vla-get-isxref item) :vlax-true)
                 (wcmatch (strcase (setq bkn (vla-get-name item))) "*TBLOCK*")
                 (< 9 (strlen bkn))
          (setq lst (cons (substr bkn 10 2) lst))
      lst
    (vl-load-com)
    2019-05
    15
    Ok that seems to be returning the correct value! However when I incorporate my next line it responds with "Error: bad argument type: stringp ("B1")"
    (defun c:Test (/ bkn lst psetup)
                 (< 9 (strlen bkn))
    (if (wcmatch (strcase (getvar "dwgname")) "*yy*")
    	 		 (setq 	psetup 	(strcat lst "xxx"))
    				(setq 	psetup 	(strcat lst "zzz"))
    "lst" is a string isn't it? So it's value can be added to something to make a new string??
    2010-06
    962
    The variable 'lst' is a list of strings and not a string and that's why you've received an error because you can't concatenate a list with a string.
    You have another mistake which is the first line while you upper case the drawing name then the compared string is in lower case.
    If the variable 'lst' may contain only one string and you are sure of this, then just use car function to get the string from the list like this:
    (car lst)
    2019-05
    15
    Yes! you are right about the lst.
    I got ahold of a sort of a work-around to convert the list into a single string.
    (defun :GetAllXrefNames  (/ blk lst)
      (vlax-for blk (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
        (if (eq (vla-get-isXref blk) :vlax-true)
          (setq lst (cons (vla-get-name blk) lst))))
      lst
    (defun LM:lst->str ( lst del )      ;CONVERTS LIST STRING TO SINGLE LINE STRING
        (if (cdr lst)
            (strcat (car lst) del (LM:lst->str (cdr lst) del))
            (car lst)
    (defun c:PAGE_CONFIG (/ lst)	;TYPE THIS COMMAND HERE	(PAGE_CONFIG)
        (vl-load-com)
    	(vlax-for y (vla-get-plotconfigurations
    		(if (/= "Model" (vla-get-name y))
    			(vla-delete y)
      (foreach xname (:GetAllXrefNames)
        (if (wcmatch (strcase xname) "*XXX*")
          (setq lst (cons (substr xname 10 2) lst))
       (if (wcmatch (strcase (getvar "dwgname")) "*ABC*")
    	 		 (setq psetup (strcat (LM:lst->str lst "") "XYZ"))
    				(setq psetup (strcat (LM:lst->str lst "") "ZYX"))
  1. Problems with wcmatch
    By deheylen690271 in forum AutoLISP
    Last Post: 2019-06-13, 12:31 PM
  2. Project Navigator - xrefs? what xrefs?
    By rodg in forum CAD Management - General
    Last Post: 2008-11-04, 08:21 AM
  3. Project Navigator - xrefs? what xrefs?
    Last Post: 2008-11-04, 08:20 AM
  4. wildcarding tblobjname BLOCK with wcmatch?
    By mnelson.92099 in forum AutoLISP
    Last Post: 2007-12-12, 07:08 PM
  5. XREFS - MSG not xrefs "Not Found"
    By spencer.67965 in forum VBA/COM Interop
    Last Post: 2005-01-18, 03:45 PM
