Thread: Create a Chamfer around an irregular shape in 2018.
    2003-09
    89
    Angry Create a Chamfer around an irregular shape in 2018.
    I have a shape that is made up of small segments That I want to put o chamfer on. In the attached PDF file you can see that the segments are 1" and vary in length across the width of the part. I have no problem creating the outside profile and extruding the part, 8". The chamfer is 1" x 45. I select all the segments around the perimeter, but when I click apply it fails. I have even tried creating a sketch of the bottom perimeter and sweeping a 1" x 45 triangle around the bottom edge and that fails as well. What am I doing wrong?
    288
    Default Re: Create a Chamfer around an irregular shape in 2018.
    Can you post the part, or something similar?
  1. 2017: hexagon shape around numbers in Mtext
    By Maverick91 in forum AutoCAD General
    Last Post: 2018-07-02, 02:26 PM
  2. Quadro M1200 for Autocad 2018 and Revit 2018
    By fredrik.schlau in forum Hardware
    Last Post: 2018-03-19, 09:09 PM
  3. Create an irregular surface from selected point in a point cloud
    Last Post: 2012-03-10, 12:15 PM
  4. Create a repeating detail along a curved or irregular line
    Last Post: 2008-01-11, 03:27 PM
  5. Mtext boundary be an irregular shape
    Last Post: 2005-10-20, 08:01 PM
