Results 1 to 10 of 14
Thread: TABLEINDICATOR = 1 row numbers and column letters do not display
    Member Shoey's Avatar
    2004-10
    Bradford, England
    35
    Default TABLEINDICATOR = 1 row numbers and column letters do not display
    Hi all,
    The variable TABLEINDICATOR in my drawing is set to 1 but when i double-click
    inside a table cell, the labels across the left side abd top do not appear.
    Am i missing something here?
    Using AutoCAD Map 3D 2007.
    Cheers
    13,656
    Question Re: TABLEINDICATOR = 1 row numbers and column letters do not display
    Hi
    Is this issue / problem occurring in all drawing files OR just the odd one or two?
    Have a good one, Mike
    2004-10
    Bradford, England
    35
    Default Re: TABLEINDICATOR = 1 row numbers and column letters do not display
    Mike,
    This happens in every drawing!
    Cheers
    13,656
    Quote Originally Posted by mark.shoesmith
    Hi
    Can you please post a drawing file for us to look at... we can then try and determine if the issue / problem is drawing based OR AutoCAD based (be it Hardware / Software / User based) OR...
    100 Club KansasCAD's Avatar
    2002-02
    Derby, Kansas
    114
    We have never been able to see these either. In any drawing. If someone has any answer I would sure appreciate you posting it here.
    We have a few summary of quantities sheets that we grab totals from one table and populate a different table (all in model space) and then we do viewports to show each table in the titleblock in a layout tab. If would sure be alot easier to track if the column and row numbers showed up.
    Thanks,
    Daryl
    2004-10
    Bradford, England
    35
    All
    I opened the drawing with the table in vanilla AutoCAD 2007 and AutoCAD 2008 which
    we have in other divisions in my office and the rows and columns show up when i edit the table.
    Then i opened the drawing up again in AutoCAD Map 2007 and when i edit the table they do not show up.
    So my computer has a problem with a setting somewhere??
    Many thanks
    13,656
    Hi Mark
    Given the above information (it would appear to be a Map 3D issue / problem), I have therefore moved this thread from the AutoCAD Tables forum to here.
    Thanks, Mike
    Forum Manager
    All AUGI, all the time Capt. Computer Crasher's Avatar
    2006-12
    South of North & East of West
    786
    Quote Originally Posted by Mike.Perry View Post
    Hi Mark
    Thanks, Mike
    Forum Manager
    Mike,
    I don't think is only in map I use both Civil 3D 2007 and Civil 3D 2008 which do have components of MAP but I am having the same problem the TABLEINDICATOR = 1 and still no column or row indicators also KansasCAD uses Civil3D as well.
    TN/KY Area
    1,640
    But in LDT2007 it works. Also note that with C3D & Map3D 2008 the tabletoolbar varible settings have no effect and acts just like the tableindicator.
    2006-12
    786
    so you concurr this is a Civil 3D /Map 3D vertical problem. I don't think AutoDesk is aware of it. I am using SP2 for Civil 3D 2008 and it still does not work. also does not work in SP3 Civil 3D 2007
  1. Adding numbers, ingoring letters
    By robert.1.hall72202 in forum AutoLISP
    Last Post: 2016-11-05, 02:09 AM
  2. Window tags with letters not numbers
    By jastuccio in forum ACA General
    Last Post: 2009-08-12, 05:17 PM
  3. Ability to have letters as well as numbers in as revision sequence numbers
    Last Post: 2007-10-01, 01:07 PM
  4. Call out sections as numbers or letters?
    By crohloff.72988 in forum CAD Standards
    Last Post: 2006-06-26, 06:44 PM
  5. sequence of numbers and letters
    By hevgee in forum AutoLISP
    Last Post: 2006-03-17, 04:43 PM
