Results 1 to 9 of 9
Thread: AutoCAD Map 3D - Performance issues
    2019-07
    6
    Default AutoCAD Map 3D - Performance issues
    Hello Community,
    since a few days the attached file has performance issues. The open process takes nearly 2 minutes within a main memory workload of 60%. After that we can work continiously in the model area. But if we want to change to the layouts (15 pcs.) and switch between them, the main memory workload increase up to 97% and AutoCAD crashes. The proof and purge commands bring no improvement and find no bugs. The TIF shortcut is deleted and frequently occurring assemblies are organised in blocks. Non of these improvements bring any changes. We work with AutoCad 2019 Map 3D.
    CPU Workload: 15% (continiously)
    Graphic card Workload: 0-1% (continiously) – is that normal?
    Computer We work with Lenovo Thinstations P520C (16 GB main Memory, 4.00GHz CPU, 4 processor cores and a NVIDIA Quadro P2000 graphic Card). We have the problem on all our computers.
    Performance try outs
    We try to deaktivate Hyper Threading (Lenovo Performance Manager), on processor core is only for AutoCAD reserved and we dont run Auto CAD in compatibilty mode with older windows versions.
    Our normal Workflow
    Other dwg files with the same scale run at a main memory workload of 30%. If we switch between the layouts the workload increases up to 50% but not much. But Auto Cad runs not 100% smooth.
    If you have any other ideas for performance or handling improfements of this scale of dwg files please let us know. (maybe work with xref or sheetsetmanager)
    Attached file (Wetransfer Link)
    https://we.tl/t-B647tiEjF2
    Please only copy the https part.
    We hope you can help us.
    Kind regards
    EG
    2019-07
    6
    Default Re: AutoCAD Map 3D - Performance issues
    We also tried following steps:
    *Overkill
    *Purge
    *WBlock
    *Delete layerfilter
    *Delete unused scales
    *Delete block from high amount
    all of that habe no improval effects and downgrade the dwg file from 32 to 31 MB.
    6,419
    You can't attach a file that large to the forums. If you have Dropbox or OneDrive, you can make a temporary folder, make it Public and then post the link here. Then when your issue is solved, you can delete your public folder.
    LinkedIn
    2019-07
    6
    I did it with weshare, the link is in the post
    6,419
    Ah, because you have only 5 posts, our spam filter is blocking your link, so I didn't see it. Here it is for others to see.
    LinkedIn
    6,419
    I wasn't able to get Map to crash, but I have more memory than you (32 gb system, 24 gb video).
    The drawing structure could be improved. I group it into two areas. Scale and organization.
    Scale
    Your dwg units are milimeters but your model is in meters, but scaled down. Blocks units are in meters (and there are thousands of them) need to get scaled upon insertion (meters>milimeters), then scaled according the insertion scale of 1000 which you have manually applied. And it is a large number of units away from 0,0, which is a known issue. Besides causing a lot of calculations, this also affects organization. You have to scale your text and other items that should be in paperspace. Your paperspace viewports have to use non standard scales (although your scale is listed as 1:4500, its still in mm not m).
    Organization
    Your title block info should be in paperspace, not modelspace. When you have a ps viewport to show the tb info, acad has to calculate everything in the viewport, even if it is not seen. This is similar to the difference between layer on/off and layer freeze/thaw. Both don't display entities when off/freeze, but off still keeps ents in memory and calculates them. Freeze removes them from memory and does not perform calcs on them. So if you have 4 viewports, 1 for the model and 3 for tb info, then acad has to perform calculations on the model entities 3 extra times. If you still need to keep the title block info in model space, at least freeze the unnecessary layers in each vp.
    The model is overly complicated for what is shown on the layouts. There is too much info and the plot just looks almost totally black. You could freeze the layer "DC_module rows" and/or replace it with a less dense hatch for example. The hatches for the laydown areas are very dense too. If you need it that dense, you might consider using a solid hatch and a background mask for the text.
    There is a lot of non-graphical stuff that probably isn't being used but the PURGE command will not handle. It seems that at one point, C3D was used. To get rid of that info, you need to do it from C3D using one of the EXPORTTOAUTOCAD commands.
    Try some of these suggestions and it should improve things.
    LinkedIn
    2019-10
    Great post. Thank you!
  1. AutoCAD Map 3D - Performance
    By erikgruener783628 in forum AutoCAD Map 3D - General
    Last Post: 2019-07-24, 08:45 AM
  2. Help! AutoCAD performance issues
    By sblackburn in forum AutoCAD General
    Last Post: 2009-11-06, 10:54 PM
  3. Performance Issues with AutoCAD 2010?
    By mboyer in forum Hardware
    Last Post: 2009-06-29, 05:54 AM
  4. Replies: 8
    Last Post: 2007-01-16, 03:02 PM
  5. Performance issues with AutoCAD over a WAN
    By scott.campbell in forum ACA General
    Last Post: 2006-08-23, 04:54 PM
