Thread: Removing "for each tab" function
    2019-05
    8
    Default Removing "for each tab" function
    For the life of me, I can not seem to successfully remove the "for each tab" function, and make this PlotPDF for one tab (current) only.
    I thought it would be so simple! Please help me, what am I missing!?
    (defun C:Gen-Plot-Single-PDF (/ savepath tab dname)
    			(setvar "filedia" 0)
    	(setq savepath (strcat (getvar "DWGPREFIX") "ProgressPrints\\"))
    	(setq PathTest (C:Gen-CreateDirectory savepath))
      	(if (= PathTest T)
    	(progn
      		(foreach tab (layoutlist)
    	  		(if (= (length (layoutlist)) 1)
    				(setq	dname (strcat savepath (vl-string-subst (strcat " " tab) ".dwg" (getvar "dwgname"))))
    				(setq	dname (strcat savepath (vl-string-subst (strcat "-" tab) ".dwg" (getvar "dwgname"))))
        			(setvar "ctab" tab)
    			(command "-plot" "y" tab "DWG to PDF.pc3" "" "m" "l" "n" "l" "" "" "y" "" "y" "n" "n" "n" dname "n" "y")
    			;SOLVE: if theres eror = prompt
    	  );progn
    	(princ "Failed to create folder path. Please create \"ProgressPrints\" file path manually in build folder")
    	);if
      		(setvar "filedia" 1)
      	(princ)
    );defun
    All AUGI, all the time Tharwat's Avatar
    2010-06
    897
    Default Re: Removing "for each tab" function
    Hi,
    Something like this ?
    NOTE: I don't think that you need to disable the system variable FILEDIA since you already have used the dash symbol before the plot command and this won't show the dialog in any case unless you have it for something else.
    (defun C:Gen-Plot-Single-PDF (/ tab savepath PathTest dname)
      (if (= (setq tab (getvar "ctab")) "Model")
        (alert "Must be on layout tab to continue.")
        (progn
          (if PathTest
            (progn
      (princ)
    2019-05
    8
    Yes Yes YEEEEESS!! Thank you so much.
    Ok, I wasn't too sure how important that was either, as it seemed to work fine without it.
    Thanks again!!
    2003-07
    334
    This will plot a range or just 1 layout
    2010-06
    897
    Quote Originally Posted by mruu88781911 View Post
    Thanks again!!
    Excellent.
    You're most welcome.
  1. Replies: 2
    Last Post: 2016-12-22, 01:02 PM
  2. For each...next within for each...next
    By CADfunk MC in forum VBA/COM Interop
    Last Post: 2009-05-15, 05:01 PM
  3. Replies: 5
    Last Post: 2009-04-17, 10:10 AM
  4. Revit removing my tab-indenting on blocks of text
    By AaronC in forum Revit MEP - General
    Last Post: 2008-11-19, 04:17 PM
  5. Saving each Tab separately to own DWG file
    By todd.mackay in forum AutoLISP
    Last Post: 2005-12-14, 03:51 PM
