Thread: Feature line elevation from point
    Raleigh, NC
    944
    Default Feature line elevation from point
    It would seem that if I am drawing a feature line and I snap to the Civ3d point that it would assign the elevation assigned to the point.
    Is it possible to do that?
    9,805
    Default Re: Feature line elevation from point
    How are you drawing the feature line?
    If using object snap, then is OSNAPZ set to 0?
    That works for me.
    I was also able to use the 'PN transparent command and provide a list of point numbers (e.g.: 3- and the resulting FLine vertices were at the correct elevations.
    Using the 'PO transparent command also works.
  1. 2016: Feature Line Point Symbol
    By rmk in forum AutoCAD Civil 3D - General
    Last Post: 2016-09-23, 08:41 PM
  2. Replies: 2
    Last Post: 2015-11-13, 07:52 PM
  3. CV104-1P: One Point, Two Point, Red Point, Blue Point
    By Autodesk University in forum Civil Infrastructure
    Last Post: 2013-05-05, 03:17 AM
  4. CV12-4: One Point, Two Point, Red Point, Blue Point
    Last Post: 2013-04-17, 04:50 AM
  5. Replies: 0
    Last Post: 2010-09-21, 02:11 PM
