Thread: Freezing Layers In Exiasting Viewports
    2015-10
    2
    Question Freezing Layers In Exiasting Viewports
    Hi
    I have CAD plans with lots of viewports, each set up for different layer sets. Is there a way if I cut and past an object into a file or bring layers in to a file through Design Centre, that the layer is Frozen in EXISTING viewports as well as New viewports?
    The layers I'm inserting are set to be frozen in view ports In the source drawing. I can use the button "New Layers VP frozen in All Viewports" in LAYERPROPERTYMANAGER, but this is very cumbersome as I have to add all the layer details manually.
    I'm currently using AutoCAD 2018
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL
    3,264
    Default Re: Freezing Layers In Exiasting Viewports
    You can use the VPLAYER command with either:
    Newfrz (New Freeze)
    Creates new layers that are frozen in all viewports.
    Vpvisdflt (Viewport Visibility Default)
    Thaws or freezes the specified layers in subsequently created viewports.
    Tom Beauford P.S.M. - Civil 2019 on Windows 10 Enterprise
    Design Analysis - Leon County Public Works/Engineering Wrap [CODE] tags around selected text
    Ph# (850)606-1516 Home Page
    2015-10
    2
    Hi - Perfect
  1. Replies: 14
    Last Post: 2010-03-24, 05:13 AM
  2. Lisp help with freezing layers within blocks in layouts.
    By christian.knudsen in forum AutoLISP
    Last Post: 2008-10-08, 01:44 PM
  3. Replies: 2
    Last Post: 2008-09-23, 02:16 PM
  4. Freezing Layers in Tabs
    By lonewolfjustin in forum AutoCAD General
    Last Post: 2008-06-13, 03:48 PM
  5. Xclip freezing layers automaticly
    By IanR in forum ACA General
    Last Post: 2006-08-04, 11:40 PM
Tags for this Thread
