Thread: how can we create multiple dimensions on same distance between two polylines in autocad
    2017-06
    Default how can we create multiple dimensions on same distance between two polylines in autocad
    i want create multiple dimensions on same distance between two polylines in autocad
    2003-07
    418
    Default Re: how can we create multiple dimensions on same distance between two polylines in autocad
    You need to provide more information the actual method is simple using VL lisp functions.
    In Civil engineering terms its a peg and shift.
    The better solution is to pick 1 side and do say intervals and vertices. It has been solved before. As a 1st step google pretty sure its already available.
    This is similar request https://www.cadtutor.net/forum/topic...sion/#comments
  1. 2016: Can I transfer keynote parameter between files between same families?
    By zzzzaaaa in forum Revit - Platform
    Last Post: 2018-05-24, 08:01 PM
  2. 2017: Can't create local project file from central file on one macnine, but can on two others on same network
    By Itinerent Revit Instructor ( IRI ) in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2017-01-07, 07:35 PM
  3. Replies: 15
    Last Post: 2007-04-25, 01:51 PM
  4. Replies: 2
    Last Post: 2006-07-24, 10:42 PM
  5. Leave a certain distance (gap) between two lines
    By Olaf.Banckaert in forum AutoCAD General
    Last Post: 2006-03-09, 11:29 PM
