Results 1 to 1 of 1
Thread: pls help to create "user defined mapcslibrary.csd" file
    2001-11
    14
    Default pls help to create "user defined mapcslibrary.csd" file
    I have recieved the esri prj file for projection parameters
    PROJCS["Pak I",GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Lambert_Conformal_Conic"],PARAMETER["False_Easting",2743196.4],PARAMETER["False_Northing",914398.8],PARAMETER["Central_Meridian",68.0],PARAMETER["Standard_Parallel_1",29.655],PARAMETER["Standard_Parallel_2",35.314],PARAMETER["Scale_Factor",1.0],PARAMETER["Latitude_Of_Origin",32.5],UNIT["Meter",1.0]]
    should I got a user defined .csd file based on these parameters (preferably in FEET)
  1. Walls defined as families with user defined parameters
    By J-G in forum Revit Architecture - Wish List
    Last Post: 2021-04-01, 12:53 PM
  2. 2014: Annotative text "Paper defined" and "Model defined" height?
    By sandeep_koodal in forum AutoCAD General
    Last Post: 2014-10-29, 06:02 AM
  3. 2013: Pls Help!!! Pls...Link Dimension not showing up..
    By limruian in forum Revit Architecture - General
    Last Post: 2014-03-19, 04:10 AM
  4. Replies: 7
    Last Post: 2010-07-01, 11:18 AM
  5. Two Ceilings - How do I make them? was..."pls see this"
    By mj_lampad@yahoo.com in forum Revit Architecture - General
    Last Post: 2010-04-24, 03:50 PM
