Thread: Burst all blocks...
    2011-09
    308
    Default Burst all blocks...
    Hiya gang,
    I have this simple routine that ALMOST works. it shoudl select all blocks and issue the burst command, however...
    It prompts me to select objects.
    If I type "ALL" and press ENTER it does exactly what I want. But the ssget line should take care of that... I thought.
    What Am I missing?
    (defun c:BurstAll (/ ss )   (if (setq ss (ssget "_X" '((0 . "INSERT") (66 . 1))))
          (command (c:Burst) ss "")
    Thanks as always,
    -JP
    Tallahassee, FL USA
    3,658
    Default Re: Burst all blocks...
    Try:
    		(progn
    		  (load "Burst.lsp") ; will only autoload when entered at command line.
    		  (sssetfirst nil ss)
    		  (c:Burst)
  1. 2008: Possible to Explode/Burst Blocks and Maintain Xclips?
    By ReachAndre in forum AutoCAD General
    Last Post: 2011-11-09, 01:01 PM
  2. Burst & Dynamic Blocks
    By shadow_kris in forum AutoCAD General
    Last Post: 2008-01-29, 06:14 PM
  3. use BURST instead of EXPLODE
    By ceekayem in forum AutoCAD Tips & Tricks
    Last Post: 2006-01-20, 05:21 PM
  4. Using BURST instead of EXPLODE
    By ryan.87191 in forum AutoCAD General
    Last Post: 2005-09-12, 09:35 PM
