hlambing715030
Tom Beauford P.S.M Per your comment "We have Description Key Codes for points like property corners that are often not at ground level, but would never include those in a surface or label their elevation."
Us too but these automatically go to either traverse layer or monumentation layer. And I turn them off for the engineers.
How exactly do you handle these types of points. Telling a surface to ignore pcodes or a ranges of points is easy.
But how do you get ACAD to not show some points that have good elevations but use the same pcode as other points with bad elevations.
Is there something in styles I'm missing that would automatically use a marker style of none or a dot for the null/0 elev points but still use the proper marker for the same pcode when an elevation is correct.
