Thread: PyRevit Task Dialog Issue
    2014-03
    2
    Default PyRevit Task Dialog Issue
    I have created a script for PyRevit, using python code tested in RevitPythonShell (see code below). The script is designed to let the user select one of our panel schedule title blocks, get all of the elements contained within the schedule tables on that sheet, then add the Sheet Schedule Number (Sheet Number) to all of the panels for that sheet. This script was working in both RevitPythonShell and PyRevit, however it now throws an error when run from PyRevit, saying " pickobject NameError: global name '__window__' is not defined.
    It referes to line 41 & line 30 in the code which contains __window__.Hide()
    I'm really stuck and can't find the issue, please help.
    """Sets the Schedule Sheet Number to all of the Elements that appear on the Schedule"""
    __title__ = 'Set Sched No\nTo Items On\nSchedule'
    #import libraries and reference the RevitAPI and RevitAPIUI
    from Autodesk.Revit.DB import *
    from Autodesk.Revit.DB.Architecture import *
    from Autodesk.Revit.DB.Analysis import *
    from Autodesk.Revit.UI import *
    import clr
    # clr.AddReferenceByName("PresentationFramework, Version=3.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35")
    # clr.AddReferenceByName("PresentationCore, Version=3.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35")
    clr.AddReferenceByPartialName('PresentationCore')
    clr.AddReferenceByPartialName("PresentationFramework")
    clr.AddReferenceByPartialName('System.Windows.Forms')
    import System.Windows
    #set the active Revit application and document
    app = __revit__.Application
    doc = __revit__.ActiveUIDocument.Document
    uidoc = __revit__.ActiveUIDocument
    activeView = doc.ActiveView
    # define function pickobject()
    def pickobject():
    from Autodesk.Revit.UI.Selection import ObjectType
    __window__.Hide()
    picked = uidoc.Selection.PickObject(ObjectType.Element, \
    'Pick the Titleblock on the required sheet')
    __window__.Show()
    __window__.Topmost = True
    return picked
    # Instructs User to select the TitleBlock on
    # the required Shedule Sheet with a Dialog Box
    TaskDialog.Show('Selection','Please select the Titleblock on the required Schedule Sheet')
    # Gets the Selected TitleBlock to Extract Sheet Number
    sheets = doc.GetElement(pickobject())
    # Stores Sheet Number as string under variable h
    h = sheets.LookupParameter('Sheet Number').AsString()
    # Confirms the Selected Sheet Number with a Dialog Box
    TaskDialog.Show('Result', 'The Sheet Number of the selected sheet is \n'+h)
    # Collect All Sheets in project to find Sheet Element
    # matching selected Sheet Number
    Shtlist = []
    ShtNums = []
    ShtElems = FilteredElementCollector(doc).OfClass(ViewSheet).ToElements()
    # Check for matches between sheet 'Sheet Number' \
    # and selected titleblock 'Sheet Number'
    # Where it matches add sheet element to elementlist
    for e in ShtElems:
    num = e.LookupParameter('Sheet Number').AsString()
    if num == h:
    ShtNums.append(num)
    Shtlist.append(e)
    # SelSheet is the Sheet host of the selected titleblock.
    # Get ScheduleViews on the sheet.
    SelSht = Shtlist[0]
    SelShtNo = SelSht.LookupParameter('Sheet Number').AsString()
    print (str(SelShtNo))
    elementlist = []
    for sheet in Shtlist:
    try:
    viewlist = list()
    collector = FilteredElementCollector(sheet.Document, sheet.Id) \
    .OfClass(ScheduleSheetInstance)
    for item in collector:
    viewlist.append(sheet.Document.GetElement(item.ScheduleId))
    elementlist.append(viewlist)
    except:
    elementlist.append()
    schtables = elementlist[0]
    NoSch = len(schtables)
    print(NoSch)
    # Gets Elements in each Schedule Table and puts them into lists = listElemOnSch
    listElemOnSch = []
    for sch in schtables:
    collector = FilteredElementCollector(doc, sch.Id)
    listElemOnSch.append(collector.ToElements())
    # Transaction to write the schedule number to all the elements in
    # schedule tables on the selected sheet
    t = Transaction(doc, 'Write Schedule No. to items on schedule')
    t.Start();
    for listElems in listElemOnSch:
    print(str(len(listElems)))
    for elems in listElems:
    param = elems.LookupParameter('SCHEDULE_No.')
    param.Set(SelShtNo)
    t.Commit();
    2014-03
    2
    Default Re: PyRevit Task Dialog Issue
    I think I've fixed it, I have commented out the lines that refer to '__window__'. it must be a quirk of the RevitPythonShell, requiring these lines but pyRevit not showing a selection window.
  1. Titleblock - issue date and type of issue placed in issue column
    By jdrexler in forum CAD Management - General
    Last Post: 2006-04-10, 05:01 PM
  2. pyRevit -email address
    By GuyR in forum Revit - API
    Last Post: 2005-06-03, 09:11 PM
Tags for this Thread
