Thread: my block dinamic hatch can not change length and angle
    Default my block dinamic hatch can not change length and angle
    i have code to dinamic block using hatch but while distance1 is changed and angle1 is changed
    my hatch can not update distance1 and angle1
    please help every body
    Sub test1()
     Dim j  As String, Sudut As Double, jarak As Double
     Dim a As AcadBlockReference
     jarak = ThisDrawing.Utility.GetString(1, vbCrLf & "Masukkan Jarak: ")
     x = ThisDrawing.Utility.GetPoint(, "Klik titik awal")
     jarak = CDbl(jarak)
     Sudut = Atn(1)
     Set a = ThisDrawing.ModelSpace.InsertBlock(x, "a1", 1, 1, 1, 0) 'a1 ganti dengan nama blokc
              If a.IsDynamicBlock = True Then
               Props = a.GetDynamicBlockProperties
                   For Index = LBound(Props) To UBound(Props)
                       Set prop = Props(Index)
                           If prop.PropertyName = "Distance1" Then
                                prop.Value = jarak
                           ElseIf prop.PropertyName = "Angle1" Then
                                prop.Value = Sudut
                           End If
                           ThisDrawing.Regen acAllViewports
                   Next Index
                End If
    End Sub
    Default Re: my block dinamic hatch can not change length and angle
    this is my image please help me what is wrong
    5,682
    Your hatch was not included in the stretch action. I redefined it by modifying the stretch action's selection set and doing a crossing window using points 1,2. After that, the code worked...with modifications. You had 4 variables that were not dimensioned. If you add Option Explicit to the top of each module as shown, the IDE will notify you if you try to use a var that has not been dim'ed. If you set Require Variable Declarations in your VBA options, it will add Option Explicit to new modules.
  1. Dinamic Block
    By BILLYJOW in forum Dynamic Blocks - Technical
    Last Post: 2013-01-30, 04:04 PM
  2. Help - Dinamic block
    Last Post: 2013-01-22, 12:06 PM
  3. Visibility States - Dinamic Block
    Last Post: 2012-11-30, 04:13 PM
  4. 2012: DINAMIC BLOCK
    By Scooby in forum Dynamic Blocks - Technical
    Last Post: 2012-08-27, 02:26 PM
  5. HELP - DINAMIC BLOCKS
    Last Post: 2012-08-24, 04:59 PM
