Results 1 to 9 of 9
Thread: Lisp that sends wipeouts to the back of the drawortder inside blocks not working in 2019
    I could stop if I wanted to jpcadconsulting347236's Avatar
    2011-09
    300
    Default Lisp that sends wipeouts to the back of the drawortder inside blocks not working in 2019
    Hiya gang,
    Lee Mac wrote this lisp for me a while back that send wipeouts inside blocks to th eback of the draworder. It worked great for years and now in AutoCAD 2019, it seems to have stopped working.
    Hopeing somebody can shed some light on this for me.
    Lee Mac's Code:
    (defun c:BlockWipeoutToBack (/ acdoc)
      ;; Lee Mac 20.06.11
      (setq acdoc (vla-get-activedocument (vlax-get-acad-object)))
      (vlax-for block (vla-get-blocks acdoc)
        (if
          (and
            (eq :vlax-false (vla-get-islayout block))
            (eq :vlax-false (vla-get-isxref block))
            (lambda (/ lst)
              (vlax-for obj block
                (if (eq "AcDbWipeout" (vla-get-objectname obj))
                  (setq lst (cons obj lst))
              (if lst
                (vla-movetobottom
                  (LM:SortentsTable block)
                  (vlax-make-variant
                    (vlax-safearray-fill
                      (vlax-make-safearray
                        vlax-vbobject
                        (cons 0 (1- (length lst)))
                      lst
      (vla-regen acdoc acallviewports)
    (defun LM:SortentsTable (space / dict result)
      (cond
         (not
           (vl-catch-all-error-p
             (setq result
                    (vl-catch-all-apply
                      'vla-item
                      (list (setq dict (vla-GetExtensionDictionary space))
                            "ACAD_SORTENTS"
         result
        ((vla-AddObject dict "ACAD_SORTENTS" "AcDbSortentsTable"))
    (vl-load-com) (princ)
    James Pertusi
    CAD Applications Consultant
    1 (646) 773 4834
    www.jpcadconsulting.com
    5,536
    Default Re: Lisp that sends wipeouts to the back of the drawortder inside blocks not working in 2019
    Works fine here (C3D 2019.3)
    2011-09
    300
    Crazy. Maybe my blocks? Hard to believe all of them suddenly became unresponsive to this command. I've attached a file with a few. Does it still work for you?
    James Pertusi
    1 (646) 773 4834
    5,536
    Quote Originally Posted by jpcadconsulting347236 View Post
    Still works fine here (C3D 2019.3):
    2005-07
    40
    Works in AutoCAD 2019.1.2 on my end, similar to BlackBox … have you added any new routines to your setup?
    Tallahassee, FL
    3,366
    Even works on my Civil 3D 2019 that doesn't have any updates.
    Ph# (850)606-1516 Home Page
    2011-09
    300
    Super weird.
    Works fine in our NYC office, not in the Cambridge office. Same version, same support files...
    Could it be some setting in AutoCAD or a driver issue?
    James Pertusi
    1 (646) 773 4834
    2011-09
    300
    Acad version is older in Cambridge. Updating now to see if that's it.
    James Pertusi
    1 (646) 773 4834
    2011-09
    300
    I'll be darned. After the update it works. Who knew?
    Thanks for your help folks... always appreciated.
    Now back to trying to wrap my brain around reactors.
    James Pertusi
    1 (646) 773 4834
  1. 2014: DWG Nested Inside Detail Comp. > Nested Inside Profile > Nested Inside Window
    By edu.rocha.tavares in forum Revit Architecture - Families
    Last Post: 2013-11-26, 06:46 PM
  2. Joining Channels to Angles sends components skewing at odd angles. (REVIT Struct 2012)
    By Melissa.Stewart1980 in forum Revit Structure - General
    Last Post: 2012-05-25, 05:56 PM
  3. Publishing sends all other windows to background
    By toddbatterman in forum AutoCAD Plotting
    Last Post: 2010-01-30, 12:19 AM
  4. Plotting through sheet set-sends 3 drawings and crashes
    By okillham in forum AutoCAD Plotting
    Last Post: 2006-04-13, 02:38 PM
