Thread: entsel point
    2013-03
    38
    Default entsel point
    Hi all,
    I have below a simple instructions to get the perpendicular distance from a LINE/XLINE to a point. The user selects the line or xline and I use the "selection point" from entsel in the calculations in the program. The problem is, the program works great whenever I use a "snap" like "near" or "endpoint" when using entsel. If I just select the entity (line or xline) the number I get is slightly off. Any suggestions?
    Thanks
    PS
    I'm sure there is a much fancier/simpler way of doing what I'm doing but this is what I got
    (defun *error* (msg)
      (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")
          (princ (strcat "\n; error: " msg))
    (setq ent (entsel))
    (setq entPt (cadr ent))
    (setq entDef (entget (car ent)))
    (setq ent (car ent))
    ;check ent is line or xline
    (cond
       (or (= (cdr (assoc 0 entDef)) "LINE")
           (= (cdr (assoc 0 entDef)) "XLINE")
       (setq lPt1 (cdr (assoc 10 entDef))
         lPt2 (cdr (assoc 11 entDef))
       (if (= (cdr (assoc 0 entDef)) "XLINE")
         (setq beta (angle lPt1 (mapcar '+ lPt1 lPt2)))
         (setq beta (angle lPt1 lPt2))
      (T
       (princ "Entity must be 'XLINE' or 'LINE'")
       (exit)
    (setq toPt (getpoint "\nto point"))
    (setq L (distance toPt entPt))
    (setq theta (angle entPt toPt))
    (setq alpha (- theta beta))
    (setq a (abs (* L (sin alpha))))
    (princ a) ; 'a' is perpendicular distance to point selected with 'entsel' and 'toPt'
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL
    3,353
    Default Re: entsel point
    Without complete code or a better description of what you're doing couldn't you simply snap to Perpendicular using 'DIST?
    Tom Beauford P.S.M. - Civil 2020 on Windows 10 Enterprise
    Design Analysis - Leon County Public Works/Engineering Wrap [CODE] tags around selected text
    Ph# (850)606-1516 Home Page
    2013-03
    38
    That is something I'm going to try out. Thanks for the response. Also, the code below is what I ended up with (with the help of various CAD forums ). It does what I need.
    (defun c:rsk (/	      ent     entPt   entDef  lPt1    lPt2    beta
    	      toPt    L	      theta   alpha   dist    offset  *error*
      (setvar 'errno 0)
      (setq ent (entsel "\nFrom point:"))
      (while (= (getvar 'errno) 7)
        (setvar 'errno 0)
        (setq ent (entsel "\nSelect a point on a line or xline"))
      (setq	entPt
    	 (osnap (cadr ent) "_nea")
      (cond
        (T
         (exit)
      (setq toPt (getpoint "\nTo point:"))
      (setq L (abs (distance toPt entPt)))
      (setq dist (abs (* L (sin alpha))))
      (setq offset (getreal "\n\nEnter offset:\n"))
      (setq dist (+ dist offset))
      (setq dist (distof (rtos dist 5 4) 2)) ;rkmcswain - AUGI forum
      (command "_offset" dist ent toPt "")
  1. CV104-1P: One Point, Two Point, Red Point, Blue Point
    By Autodesk University in forum Civil Infrastructure
    Last Post: 2013-05-05, 03:17 AM
  2. CV12-4: One Point, Two Point, Red Point, Blue Point
    Last Post: 2013-04-17, 04:50 AM
  3. Help with using entsel or nentselp
    By MWKINCAID1 in forum AutoLISP
    Last Post: 2007-03-10, 12:10 AM
  4. Point from entsel
    By wommack in forum AutoLISP
    Last Post: 2006-12-15, 06:01 PM
  5. Entsel
    By fletch97 in forum AutoLISP
    Last Post: 2005-07-07, 04:37 PM
