Thread: Step through layers - if *match, then..
    2019-05
    15
    Default Step through layers - if *match, then..
    Hi.
    I'm trying to write a bit of code that steps through my layers, and if there's a match of "*EXIST", it runs the function I've written up. Else, moves on to the next.
    (defun c:MICKY (/ layOld layNew ss)
    (setq layOld (getvar "clayer"))
    (setq layNew (strcat layOld "-OFF"))
    ;STEP THROUGH LAYERS
    ;> IF MATCH "*EXIST" THEN...
    (setq ss (ssget "x" (list (cons 8 (getvar "CLAYER")))))
    (command "-COPYTOLAYER" ss "" layNew "y" "0,0,0" "")
    ;>ELSE NEXT LAYER
    Pretty simple function i think but I have doo-doo brain so would really appreciate any sort of help or guidance.
    2003-07
    418
    Default Re: Step through layers - if *match, then..
    So your looking for any layer that has EXIST in the name ?
    (setq doc (vla-get-activedocument (vlax-get-acad-object)))
    (vlax-for layer (vla-get-layers doc)
    (if (= (wcmatch  (vla-get-name layer) "*EXIST") T)
    (alert "match found")
    (alert "not found")
  1. Looking for step by step guide for Civil 3D 2006 or 2007
    By sergio_garces_salgado in forum AutoCAD Civil 3D - General
    Last Post: 2006-08-23, 06:12 PM
  2. Step by step guide - create two set-ups
    By VBOYAJI in forum AutoCAD CUI Menus
    Last Post: 2006-03-20, 11:14 PM
  3. Step-by-Step explanation window does not appear any more
    By dbrach in forum AutoCAD LT - General
    Last Post: 2005-12-04, 11:37 PM
