Thread: List blocks of the same name and find block insert points
    2010-04
    2
    Default List blocks of the same name and find block insert points
    Hi friends,
    I wanted to do a different lsp work to count blocks. But I have a problem with listing. Tell me what I want to do;
    I can count the blocks of the same name, find out how many of them are. I want to create a separate selection set for each block so that I can find the block insert point that belongs to each block. I see this insert point with dxf codes. But I have to make a selection set list. Every block counted on the list is first, second, third.
    I will write to the block insert point with the text command. So I need to create a list and find the block insert point for each block.
    Can you help me create a list for selected / counted blocks?
    My counting lisp code :
    ;; Block counting add-on for Autocad.
    ;; According to the block name, the number of blocks in the drawing is determined.
    ;; For the user, the counted block name and the number of blocks are reported.
    (defun c:blkcnt (/ blkselect entitylist blkname blkssget blkcount)
    (setq blkselect (car (entsel "\n Select Block to be counted :"))) ;; <Entity name: 7ff7b7e97b80>
    (setq entitylist (entget blkselect)) ;; Entity listed in all
    (setq blkname (cdr(assoc 2 entitylist))) ;; Block name shown
    (if blkname
    (progn
    (setq blkssget (ssget "X" (list (cons 2 blkname))))
    (if blkssget
    (setq blkcount (sslength blkssget))
    (cond ( (> blkcount 1)
    (alert (strcat "\n Block name : " (strcase blkname) " from " "\n Total :" " " (itoa blkcount) " There are pieces !")) )
    ( (= blkcount 1)O
    (alert (strcat "\n Block name : " (strcase blkname) " Only 1 piece available !")))
    ( t
    (alert (strcat "\n Block name : " (strcase blkname) " No have block with this name !!! ")))
    (princ)
    Sample coding for block insertpoint :
    (setq blkselect (car (entsel "\n Select a block :"))) ;; <Entity name: 7ff7b7e97b80>
    (setq blkpoint1 (cdr (assoc 10 entitylist)) ) ;; İnsert poit ;; (115.982 59.3608 0.0)
    ;; To get the insertion point of the block :
    ;; (setq blkpoint (cdr (assoc 10 entitylist)) )
    ;; To get the name of the block :
    ;; (cdr(assoc 2 entitylist))
    2010-06
    962
    Default Re: List blocks of the same name and find block insert points
    Hi,
    Something like the following ?
    (defun c:blkcnt (/ blkselect entitylist blkname blkssget blkcount dxf_lst ins_lst)
      (if (and (setq blkselect (car (entsel "\n Select Block to be counted :")))
               (setq blkname (cdr (assoc 2 entitylist)))
        (if (setq blkssget (ssget "X" (list (cons 2 blkname))))
          (progn
            (cond ((> blkcount 1)
                  ((= blkcount 1)
            (repeat blkcount
              (setq dxf_lst (entget (ssname blkssget (setq blkcount (1- blkcount)))))
              (setq ins_lst (cons (cdr (assoc 10 dxf_lst)) ins_lst))
      (if ins_lst ins_lst (princ))
    2003-07
    560
    If you get ALL blocks save name and insertion point into list. Then Vl-sort list on name, then use a simple compare of each two items in list and can make a new list of each block.
    The list would be like variable name BLK1 BLK2 etc. which can be auto created.
    (setq num 1)
    (setq lst (list "a" "b" "c"))
    ("a" "b" "c")
    (setq blk (strcat "blk" (rtos num 2 0)))
    "blk1"
    (set (read blk) lst)
    (princ blk1)
    ("a" "b" "c")
  1. Replies: 1
    Last Post: 2017-01-15, 12:22 AM
  2. Replies: 0
    Last Post: 2016-10-28, 05:44 PM
  3. Replies: 0
    Last Post: 2013-02-27, 05:40 PM
  4. Redefine block with same name on insert
    By Coolmo in forum Dot Net API
    Last Post: 2010-05-13, 11:36 PM
  5. Two Blocks with the same name in the same dwg !
    By costas.vassiliou in forum AutoCAD General
    Last Post: 2009-09-11, 01:46 PM
Tags for this Thread
