Thread: Mr. Sid images
    2004-06
    Slidell, Louisiana
    926
    Default Mr. Sid images
    I have inserted a Mr. Sid image ( 1998 ) into a dwg with a dem file to create a contour map. all is fine until
    i go to save the dwg, it asks to save the image file so i do. but then when i reopen the file the image is not where it
    was when i inserted it originally. What am i doing wrong or how do i fix this.
    i use this method a lot and it has happened every time i save the file. my only work around right now is to
    delete the image and reinsert it, which takes a few minutes (5-10).
    thanks
    Cairo - no, not Illinois
    4,983
    Default Re: Mr. Sid images
    why not use MapIInsert with the SID?
  1. 2012: Ghost Images and Lines On-Screen and in Exported Images
    By cwride in forum Revit - Plotting/Printing/Exporting
    Last Post: 2012-08-15, 08:49 PM
  2. 2009 button images replaced 2008 button images
    By Rusty in forum AutoCAD CUI Menus
    Last Post: 2009-12-08, 12:34 AM
  3. Plotting Mr. Sid Raster Images
    By dbakshi in forum AutoCAD Map 3D - General
    Last Post: 2008-04-15, 04:23 PM
  4. Plotting, memory error, file w/SID images
    By kcarlsen in forum AutoCAD Civil 3D - General
    Last Post: 2008-01-11, 04:47 PM
  5. MR SID IMAGES
    By mwilson in forum AutoCAD General
    Last Post: 2007-07-18, 12:58 PM
