Thread: Door Label doesn't show the right mesure
    2017-02
    2
    Default Door Label doesn't show the right mesure
    Hi,
    I created a Door Label that shows width and height of doors to put in plan view.
    It usually works really well but today i realized it doesn't work with fractions...
    If there's a door of 36.25" (as width parameter), the label shows 36" and if there's a door of 36.75" is shows 37".
    I created the same thing for windows and i don't have that problem.
    The project units show fractions, so i know there's a problem with the label itself...
    Anyone got an idea on how to fix that?
    I've attached an image to show the problem and the label itself.
    Thanks!
    2010-10
    Chicago, IL
    376
    Default Re: Door Label doesn't show the right mesure
    Either use project settings, or change rounding.
    I would change rounding so the tag is independent from the project settings, which could be different from project to project.
    2017-02
    2
    Thanks a lot! That's exactly what i was looking for and now it works perfectly!
  1. 2014: mesure en AutoCAD 2014
    By allayahassine572348 in forum AutoCAD General
    Last Post: 2014-03-07, 06:03 PM
  2. outils mesure dans revit architecture peut mieux faire
    By loewek940608 in forum Revit Architecture - General
    Last Post: 2012-03-28, 05:02 PM
  3. Family doesn't show up right in plan
    By Arkman in forum Revit Architecture - Families
    Last Post: 2010-10-20, 05:52 AM
  4. mesure angles en degré
    By thierry.lacenaire in forum AutoCAD LT - General
    Last Post: 2009-09-16, 03:05 PM
  5. PlotDate field plots right, but doesn't show up in dwg
    By norrin in forum AutoCAD Fields
    Last Post: 2008-04-11, 09:29 PM
