Thread: Merging Saved file name with Iproperties
    2003-11
    64
    Default Merging Saved file name with Iproperties
    When I save a part file, then open said part files Iproperties the file name comes up under the general tab as it should but instead of going to the Summery/Title location it shows up under the Project/Part Number location. This means I have to change the file name position manually when I update Iproperties. Is this normal??? I have looked in various books, tutorials etc. but I haven't found any way to change this so the file name comes up under Summery/title location automatically. What am I missing.
    Hopefully not clear as mud. Thanks.
    288
    Default Re: Merging Saved file name with Iproperties
    Hello,
    I believe this is normal behavior, except for Content Center components, where a title can be defined to auto-populate the Title field. There are some workarounds.
    • If the part is not stand-alone, and will be an assy component, the Title field can be modified en-masse with a simple copy and paste in the assy BOM.
    • Use an iLogic routine to populate the field.
    I'm sure there are other options.
    HTH
  1. Revit "File Not Saved" error when saving a central file on a server.
    By jakevaj341980 in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2018-08-09, 08:13 PM
  2. Replies: 7
    Last Post: 2013-11-16, 11:44 PM
  3. Replies: 0
    Last Post: 2012-05-11, 09:52 PM
  4. Merging Cells in an Excel File
    By jgardner.79905 in forum AutoLISP
    Last Post: 2010-07-27, 03:00 PM
  5. Replies: 12
    Last Post: 2010-01-08, 07:49 PM
