Thread: Redefine blocks in all drawings within a directory
    2015-07
    Default Redefine blocks in all drawings within a directory
    Hi there,
    DOes anyone know of a lisp that will redefine a particular block in all drawings within a directory?
    2005-06
    in the upper right corner
    3,507
    Default Re: Redefine blocks in all drawings within a directory
    Quote Originally Posted by jeremy.mooring705792 View Post
    Hi there,
    Well I'm not an "expert" in this matter but that type of thing can be done with a script.
    Basically redefining the block with the -insert command.
    -insert
    "OLDBLOCK=C:\NEWBLOCK.dwg"
    0,0,0
    erase
    last
    qsave
    (you would use your block names and paths etc)
    I you have something like ScriptPro, you can make it happen to tons of drawings.
    2009-11
    5,719
    Quote Originally Posted by BlackBox View Post
    Running Scripts within AutoCAD will process the drawings in series (one at a time).
    Core Console allows for processing drawings both in series and parallel (multiple at once).
    Here's a quick example that uses DOSLib to select multiple drawings for Core Console to process in parallel, just be mindful of how many drawings you choose to process at once, based on your workstation's CPU & RAM limitations:
    First take at replacing BSU.
    Here's the core LISP routine, which uses DOSLib to prompt for multiple drawing + .SCR (script) selection:
    ** Be sure to replace the text in red as needed **
    (vl-load-com)
    (defun c:SCRM() (c:ScriptMultiple))
    (defun c:ScriptMultiple (/ app flag dwgs dwgPath script cprofile)
    ;;;  AcCoreConsole.exe [/i <input dwg>] /s <script>[/product <product>] [/l <language>]
    ;;;  [/isolate <userid> <userDataFolder>] [/readonly] [/p[rofile] <profile>]
      (if
        (and
          (setq app (findfile "accoreconsole.exe"))
          (setq flag (dos_version))
          (setq dwgs
                 (dos_getfilem
                   "Select drawing(s) to process:"
                   (if *Dwg_LastPath*
                     *Dwg_LastPath*
                     (getvar 'dwgprefix)
                   "Drawing files (*.dwg)|*.dwg||"
          (setq *Dwg_LastPath* (car dwgs))
          (setq dwgPath *Dwg_LastPath*)
          (setq dwgs (cdr dwgs))
          (setq script
                 (dos_getfiled
                   "Select a Script to run:"
                   (if *Script_LastPath*
                     *Script_LastPath*
                     "C:\\ProgramData\\Autodesk\\C3D 2019\\BatchSaveTool\\Scripts"
                   "Script (*.scr)|*.scr||"
          (setq *Script_LastPath* (vl-filename-directory script))
          (setq cprofile (getvar 'cprofile))
         (progn
           (foreach dwg dwgs
             (startapp
               (strcat
                 app
                 "\" /i \""
                 dwgPath
                 dwg
                 "\" /s \""
                 script
                 "\" /product \"C3D\" /p \""
                 cprofile
         (cond
           (dwgs (prompt "\n** No script selected ** \n"))
           (flag (prompt "\n** No drawing(s) selected ** \n"))
           (app (prompt "\n** DOSLib required ** \n"))
           ((prompt
              "\n** Unable to find \"AcCoreConsole.exe\" in support paths ** \n"
      (princ)
    Cheers
    Meaningless text so I can make this post.
    Computer Specs:
    2005-06
    3,507
    LOL
    Not meaningless.. you are the MAN!
    Thanks for posting this here, another great option for batch running scripts.
  1. Open all drawings in a directory, save, close.
    By JSimons in forum AutoLISP
    Last Post: 2020-05-08, 10:08 PM
  2. 2014: Wblock all drawings in a Directory
    By guardsman3 in forum AutoCAD General
    Last Post: 2013-04-25, 01:11 PM
  3. Redefine Blocks from Directory?
    By stusic in forum AutoLISP
    Last Post: 2012-10-24, 07:50 PM
  4. Search text within drawings, without actually opening drawings
    By Animesh Kundu in forum AutoCAD General
    Last Post: 2008-02-29, 05:34 PM
  5. I need to redefine a Block in over 100 drawings
    By Mamma Jamma in forum AutoCAD Customization
    Last Post: 2006-04-07, 09:17 PM
