Results 1 to 8 of 8
Thread: Path of Travel tool
    I could stop if I wanted to Dean Camlin's Avatar
    2002-11
    Westminster, MD, USA
    354
    Default Path of Travel tool
    Has anyone tried using the new Path of Travel tool? It's a good idea, but unfortunately the diagonal path it generates through spaces doesn't appear to be editable. Unfortunate, in that code officials tend to disapprove diagonal paths through rooms and spaces, arguing that equipment and furniture layouts often obstruct such paths. Maybe I'll add the ability to edit these paths to the wish list!
    100 Club a_meteni's Avatar
    2002-12
    Cairo
    174
    Default Re: Path of Travel tool
    Already asked here
    2002-11
    354
    Thanks, Ali. I hadn't seen that post.
    2010-10
    Chicago, IL
    376
    I haven’t used that tool too much, but how about using segments and sum up the path length in the schedule, or creating a mass as an obstruction to force one, single path the way you want? Is that going to work? …just a thought.
    2001-12
    Irvine, CA
    7,567
    I think it is a good tool for quick analysis (to find problem areas fast) but less so for documentation. There seems to be less consistency for documentation requirements from place to place so getting the tool to work for varied submission requirements is a moving target. I find that a lot of people have settled on using Railings for formal egress path documentation (replacing the line-based family approach).
    2002-11
    354
    And I like the "Path of Travel" family you developed & shared with me earlier, Steve--but it requires adding up the straight-line path segments to get the total travel distance. It really would be nice if Revit's path could be edited.
    2001-12
    Irvine, CA
    7,567
    Yeah, I told them they shouldn't release it until the path could be edited... I use a custom schedule for the egress path total on a sheet...
    2018-04
    VOLS FAN STUCK IN NOTRE DAME
    30
    We are having issues with the path of travel I haven't seen before. We are using the design options with this model. Has anyone had problems with using design options and path of travel analysis? We pick the 2 points and then the path goes thru the design option door, then around the building to the second point.
  1. 2017: Adaptive Component Path of Travel family and levels
    By revitdevil in forum Revit Architecture - Families
    Last Post: 2017-06-30, 01:01 PM
  2. Path of travel object
    Last Post: 2012-06-13, 09:17 PM
  3. Calculate a path of travel...
    By AJGKennedy in forum Revit Architecture - General
    Last Post: 2008-06-05, 03:58 PM
  4. Travel Distances
    By Roger Evans in forum Revit Architecture - General
    Last Post: 2004-06-05, 03:00 AM
