Using several unit systems in MEP models.
Summary: Being able to use different unit systems (project units) in the same MEP model by associating imperial or metrical units depending on the MEP system and/or segment.
Description: For plumbing MEP engineering, it'd be quite useful to have the capability of using different unit systems (metrical and imperial) depending on the MEP plumbing system or associating this to the segment used for pipes.
At least in my country (Spain), it's quite usual having in the same project pipes made of iron, which are named by their diameter in inches (1/4", 1/2", 12 and so on) and plastic material pipes like PVC or PPR, which are named in millimiters from the international metrical system (15mm, 20mm, 25mm and so on).
I'm not sure if this property should be associated to the MEP system itself or to the segment which piping system are configurated with, but I think it could be discussed more specifically later.
Product and Feature: Revit MEP - MEP Pipe Sizing - (Mechanical
Submitted By: rfmarinm on 10/17/2019
Re: Using several unit systems in MEP models.
This wish has been reported as granted and already in the software.
- You may not post replies
- You may not edit your posts
Forum Rules
