Thread: Frustrated Revit user being tortured against will to do keynotes in Autocad
    The Silent Type
    2019-10
    Default Frustrated Revit user being tortured against will to do keynotes in Autocad
    Reference Keynotes and Sheet Keynotes: Can someone point me to a step by step tutorial on how to create reference and sheet keynotes in Autocad Architecture, and on how the keynotes, legends, and databases work interactively?
    I have searched and searched for step-by-step tutorials, such as you might find for keynoting in Revit, but cannot find any step by step tutorials. Like literally from the first step. And then the second step. And by the way where do I find the staircase. And the railing.
    I am trying to create reference keynotes and sheet keynotes in Autocad according to the NCS, and likewise to create the keynote legends.
    Sheet Notes: I'm looking for a step by step tutorial for how to set up the keynote database for the sheet notes, so that the key marks in the keynotes read the way I would like (A1, A2, A3 instead of 1, 2, 3, 4...).
    Organization: I'm also looking for a step by step tutorial for how to organize the keynote databases for an organization.. if this is stored somewhere common, and how to set up the path for the database.
    Interactivity: I need help to understand if the keynotes and the legends are linked (similar to Revit), so that if I change it in one place it will update in another (?)…. or if I need to somehow update the database and then reload in the drawing, in order to update notes or key marks, or if the keynotes and legends are just dumb entities in Autocad that aren't linked, except the initial time when the legend is created.
    Keynotes in Standard Autocad: Some people in my organization are using standard Autocad (not Architecture). Can someone clarify if keynoting is available in standard Autocad?
    Thanks for any help to clarify this process.
    5,655
    Default Re: Frustrated Revit user being tortured against will to do keynotes in Autocad
    Keynotes are not available in standard acad. Melinda Heavrin has written a lot of articles about ACA for AUGIWorld. You could search those magazines. I believe that was covered. You can find them under the Publications menu above.
    Here's one article:
    https://www.augi.com/articles/detail...tations-in-aca
    Super Moderator CAtDiva's Avatar
    2015-10
    Where pedals spin to move wheels
    307
    Is this a one-off type of thing, or are you setting up a system for use on future projects?
    If it's a one-off, I'd use a table for the keynote legend and blocks + leaders for the keynotes in the drawings. No, there is no linkage in this system ... unless you create the keynote legend as an xref that is attached to each sheet file. Even then, the blocks are not connected to the table or the element being noted.
    Unless you are setting this up for future use and those vanilla ACAD users will become ACA users, it's not worth the headache of learning how to "keynote" like Revit does.
  1. Revit in Poland ( Frustrated Revit user...)
    By luigi in forum Revit Architecture - General
    Last Post: 2016-02-18, 04:16 AM
  2. User Defined Keynotes, Keynote Legend, Keynotes by Sheet (QUESTIONS)
    By prestonljones438185 in forum Revit - Platform
    Last Post: 2013-12-13, 12:30 AM
  3. With the Frustrated Office Policy, How Do I Add Fonts to AutoCAD
    By BeKirra in forum AutoCAD Customization
    Last Post: 2011-12-14, 10:01 PM
  4. Revit - Reference Keynotes & Sheet Keynotes on Same Sheet
    By jjsimon in forum Revit - Platform
    Last Post: 2010-06-09, 10:50 PM
  5. I love being frustrated - properties dialog/palette
    By dkuhn in forum AutoCAD General
    Last Post: 2009-05-25, 07:46 PM
