Thread: Revit Project to dwg vs. plotting
    2019-10
    4
    Question Revit Project to dwg vs. plotting
    I am looking for a .ctb file to use once a Revit Project has been exported to DWG. Is it one of the out of the box autocad .ctb pen settings? Which of course here at my new place of employment have all been customized out of the options. Thanks!
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    Default Re: Revit Project to dwg vs. plotting
    What's that exported DWG's plot style set to when you attempt to plot it? If it cannot find the ctb it may simply be set to plot using an stb file or vice versa. When you try to select another plot style in the dialog box are the one's displayed ctb's or stb's? Nobody outside your new place can help you with your company's plot styles. Typically a company named Acme may create a customized plot style called Acme.ctb or Acme.stb. It's not a good idea to customize an OOTB plot style like acad.ctb or acad.stb as nobody outside your office would be able to plot the drawings and they wouldn't be able to plot ones from outside their office. What makes you sure they've been modified?
    2004-05
    Custer, Washington
    126
    Was the revit project created in house. if so ask a co-worker for their ctb file.
  1. Replies: 7
    Last Post: 2018-05-10, 02:06 PM
  2. 2014: Plotting dwg to pdf multiple dwg's simultaneously w/ PUBLISH command
    By fmplatt530 in forum AutoCAD Plotting
    Last Post: 2015-11-04, 01:26 AM
  3. Replies: 0
    Last Post: 2015-08-07, 04:02 PM
  4. Replies: 6
    Last Post: 2006-05-23, 09:40 PM
  5. STB plotting vs. CTB plotting
    By KansasCAD in forum AutoCAD Plotting
    Last Post: 2006-02-18, 01:29 AM
