Thread: Problem with properties palette not showing current layer after insert lisp
    2001-10
    Defragging the internets.
    350
    Default Problem with properties palette not showing current layer after insert lisp
    I have noticed that when I run lisp routines to insert a block with an attribute, the properties palette does not show the current layer.
    This happens with autocad 2018.
    (defun c:test2 ()
    (setq melay (getvar "clayer"))
    (command "-layer" "m" "test" "" )
    (setvar "attdia" 0)
    (setq meattval "x")
    (command "-insert" "myblock_with_attribute" "s" "1" "r" "0" pause meattval )
    (setvar "clayer" melay)
    (setvar "attdia" 1)
    The ribbon will show the correct layer, but the properties palette shows the "test" layer.
    Any help with this?
    2001-10
    350
    Default Re: Problem with properties palette not showing current layer after insert lisp
    (defun c:test2 ()
    (setvar "attdia" 0)
    (setq meattval "x")
    (initcommandversion );;;<---this seems to help
    (setvar "attdia" 1)
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,658
    Untested:
    (defun test2 ( / melay PropOnOff meattval)
    	      PropOnOff (getvar "opmstate")
    	(if (> PropOnOff 0)(command-s "propertiesclose"))
    	(command "-layer" "m" test "" )
    	(setvar "attdia" 0)
    	(setq meattval "x")
    	(command "insert" "myblock_with_attribute" "s" "1" "r" "0" pause meattval )
    	(if (> PropOnOff 0)(command-s "properties"))
    	(setvar "attdia" 1)
  1. 2016: lisp layer properties filter current on ALL instead of xref
    By cad2018 in forum AutoCAD General
    Last Post: 2017-09-22, 11:07 AM
  2. attributes not showing in Properties palette
    By feargt in forum AutoCAD General
    Last Post: 2012-04-17, 05:05 PM
  3. Layer filter for currently selected objects in layer properties palette
    Last Post: 2010-06-09, 01:16 PM
  4. interface problem after problem after problem
    By whatisrice in forum ACA General
    Last Post: 2009-08-12, 05:06 PM
  5. Object properties palette not showing selected Objects properties
    By timothyjturner in forum AutoCAD General
    Last Post: 2007-08-10, 05:21 PM
