Thread: Attributes in Dynamic block misbehaving.
    I could stop if I wanted to jpcadconsulting347236's Avatar
    2011-09
    307
    Default Attributes in Dynamic block misbehaving.
    Hiya gang,
    I'm pretty sure I'm losing my mind.
    In the process of troubleshooting an issue with a "bad" block, I have made a simple test block, from scratch, in a new file and it exhibits the same issues. Here's the block:
    You get the idea, you can stretch the text over, position the text/landing, flip the whole thing. Easy as pie. We've all made 1000 of them.
    I added a few annotation scales to it, looks great, right?
    However, when I flip this brand new block, the attribute rotates 180 degrees in any annotation scale except the current one:
    Furthermore, if I stretch the leader, the text does not move in the other annotation scales:
    I mean... am I going wacko!?!?!?!?!? I can make this block in my sleep.
    DWG attached. Any help is, as always, much appreciated.
    Thanks,
    -JP
    James Pertusi
    CAD Applications Consultant
    1 (646) 773 4834
    www.jpcadconsulting.com
    2011-09
    307
    Default Re: Attributes in Dynamic block misbehaving.
    I have discovered that if I set MIRRTEXT to 1, the text does not rotate (it mirrors of course):
    James Pertusi
    1 (646) 773 4834
    2011-09
    307
    I also now believe it has something to do with the fact the the attribute is multi line attribute as a single line attribute does not exhibit this issue.
    James Pertusi
    1 (646) 773 4834
    Portland, OR area
    136
    Sync the annotation scales (_annoreset) and they should work correctly. Be sure the current scale shows correct when you sync the block.
    Quote Originally Posted by jpcadconsulting347236 View Post
    2011-09
    307
    No effect.
    The odd thing is that the block attached to my initial post was not from the problem file. It was a block I created from scratch in a new file. So it happens in new blocks.
    Also if I edit the block with a single line attribute the problem goes away, make the attribute multi-line and it's back.
    Thanks for your suggestion, I'll keep digging.
    James Pertusi
    1 (646) 773 4834
  1. 2016: MLEADERSTYLE - USING BLOCK FOR MTEXT HAS MISBEHAVING ATTRIBUTE
    By mmiles in forum AutoCAD Annotation
    Last Post: 2019-01-04, 06:21 PM
  2. Block with field attributes within a dynamic block conundrum
    By flash5238 in forum Dynamic Blocks - Technical
    Last Post: 2014-05-13, 07:51 PM
  3. link dynamic block parameters with block attributes
    Last Post: 2012-06-12, 06:38 PM
  4. Replies: 21
    Last Post: 2007-03-20, 02:03 PM
  5. Extract Dynamic Block Attributes, values change as Block changes
    By dave.buckberry in forum Dynamic Blocks - Technical
    Last Post: 2006-09-05, 04:38 PM
