Thread: Autosaved drawing recovery
    2019-03
    32
    Default Autosaved drawing recovery
    Just an interesting observation that may avoid an issue for someone.
    I had a drawing crash a couple of times while I was using Bedit.
    The auto recovered drawing was only of the block as I was editing it and the rest of the drawing was lost.
    Not a major issue as I have frequent autosaves but it could have been if I didn't.
    Bruce
    Earth
    9,805
    Default Re: Autosaved drawing recovery
    Have you seen this?
    This conflicts with what you're saying, although I have very little faith in these tech docs now days.
    I don't know who writes these, but many of them are simply full of bad information.
    https://knowledge.autodesk.com/suppo...n-AutoCAD.html
    R.K. McSwain | CAD Panacea |
    2019-03
    32
    This wasn't a standard autosave, rather it is the drawing recovery which operates when autocad crashes and gives you the opportunity to recover your drawing up to the last command. This recovery is only of the block edit.
    You are correct autosave doesn't work during block edit.
    Earth
    9,805
    There is no "standard" and "non-standard" autosave.
    There are autosave files, autosave backup files, and normal backup files.
    These are the files from which the internal "recovery" process may restore your drawing.
    I find it easier to just go find the file, change the file extension and open it and not mess with that palette.
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    Quote Originally Posted by bruce13557 View Post
    Bruce
    Is it possible you used the SAVE command instead of BSAVE while in the block editor?
    If you switch tabs while using BEDIT the only safe option to get out is the X on the right end of the Ribbon which will ask you if you want to save or not.
  1. Replies: 13
    Last Post: 2010-07-09, 11:58 AM
  2. Drawing Recovery Save dwgs
    By MikeM4OSU in forum AutoCAD General
    Last Post: 2008-06-02, 12:49 PM
  3. Provide a More Reliable Drawing Recovery Tool
    Last Post: 2008-01-10, 08:07 PM
  4. Drawing Recovery Manager opens occasionally for no reason
    By ultimateguruguy in forum AutoCAD General
    Last Post: 2006-03-01, 08:06 PM
  5. Drawing Errors - Inventor Needs a Recovery Option
    By bweir in forum Inventor - General
    Last Post: 2005-11-14, 08:54 PM
