Thread: How do I edit the level lines in revit?
    2009-11
    9
    Default How do I edit the level lines in revit?
    I use level lines but I don´t want that lines appear in the drawings. I want the mention of the levels.
    How do I edit the level lines in Revit?
    Thank you.
    2002-09
    Madison, WI
    5,688
    Default Re: How do I edit the level lines in revit?
    My guess would be to use an invisible line maybe for your line type, but I'm not sure you can do that. You'd then need to modify the level head family to make it look right.
    Or you simply change the 3d extents so the actual line is very small and add a long reference plane in it's place.
    Just a thought.
  1. Replies: 1
    Last Post: 2016-06-14, 01:31 PM
  2. 2013: Line Types - Hot water lines vs cold water lines vs gas lines
    By ROBP-RDS in forum Revit Architecture - General
    Last Post: 2014-08-26, 06:26 PM
  3. Replies: 3
    Last Post: 2008-10-06, 10:24 PM
  4. revit 2009 - level tag an line gone in section, level still there
    By samov in forum Revit Architecture - General
    Last Post: 2008-05-16, 03:51 PM
  5. Defpoint Lines / Construction Lines / No Plot lines
    By ykang in forum Revit Architecture - General
    Last Post: 2006-11-14, 10:30 PM
Tags for this Thread
