Thread: CONTOURS
    2004-06
    Slidell, Louisiana
    797
    Default CONTOURS
    Is there a way to draw contours and have them added in to a surface. I mean after a surface has been created and styled to show contours, but there's
    obviously something that needs to be added based on observation, can that be done. or is it done using "user contours", but I think that's for something
    generated from the surface that was built.
    Robert
    2014-08
    369
    Default Re: CONTOURS
    Look in your definitions tab of your surface. You can add the data as a contour or breakline. If I understand correctly you know where you what this data added I would create a feature line with the elevation data and add *** a breakline
    2004-06
    Slidell, Louisiana
    797
    thanks remi678731. that makes sense. i will try that.
    Robert
  1. Undo in Digitize Contours
    By sinc in forum AutoCAD Land Desktop - Wish List (Closed)
    Last Post: 2004-08-18, 06:29 PM
  2. HOW TO MANIPULATE CONTOURS?
    By jwilhelm in forum Revit Architecture - General
    Last Post: 2004-08-10, 05:44 PM
  3. Site contours moving
    By Alex Page in forum Revit Architecture - General
    Last Post: 2004-07-16, 04:32 PM
  4. Contours with flat spots
    By Clyne Curtis in forum Revit Architecture - General
    Last Post: 2004-04-09, 03:29 PM
  5. Site Contours
    By JTF in forum Revit Architecture - General
    Last Post: 2003-09-06, 02:18 AM
