Thread: Civ 3D label issues via Xref
    Raleigh, NC
    937
    Default Civ 3D label issues via Xref
    What can I do to get the Civil 3D labels to display properly when I attach the file as an X Ref?
    The issue is the same I an having with Surface Contours becoming completely solid when attaching Civil 3D file to another too. The X Ref is taking on the layer value (Linetype=continuous) its put on.
    Raleigh, NC
    937
    Default Re: Civ 3D label issues via Xref
    Answer: xrefoverride = 0
    Cairo - no, not Illinois
    5,069
    do the labeling in the sheets, not the base file
    dataref your surfaces into the sheets, not the base file
    DRefs are your friend, and controlling labels means labeling only what's needed, where it's needed.
  1. 2014: Civ 3D 2014 - Drain Query
    By Lines&Circles; in forum AutoCAD Civil 3D - General
    Last Post: 2013-05-06, 11:25 AM
  2. Feature lines as cracks - CIV 3D 2010
    By William.Gares in forum AutoCAD Civil 3D - General
    Last Post: 2010-09-11, 12:07 PM
  3. realistic view in civ 3d
    By wag24 in forum AutoCAD Civil 3D - General
    Last Post: 2008-11-23, 05:29 AM
  4. 2008 SCALE 1:100 xref xref xref xref- scale list issues
    By Apsis0215 in forum AutoCAD Customization
    Last Post: 2008-11-21, 08:17 PM
  5. Replies: 12
    Last Post: 2005-08-10, 07:50 PM
