Pipe/Duct/Conduit Connector Elements
Summary: To add parameters to the connectors elements in Revit to allow for coupled pipes/ducts/conduit to be joined without the use of flanges.
Description: Our company has been using fabrication parts inside of Revit for the last few years, and their functionality is "OK" at best. I am not a big fan, but members of my team seem to like them because they are easy to use, and they come as a tool pallet. But as an admin, I struggle every time I have to reload a configuration (the reload times and multiple errors where parts were deleted in the central model. Or it says "you don't permission edit the element" and after 45 minutes of waiting for the changes to take place and nothing happens due to these errors). Additionally, the issues I have hangers and their reports or lack of information in them is enough to drive any sane man crazy. I don't believe Autodesk knows how exactly how close they are to being able to make the most significant change in Revit pipe families that people are looking for on the piping and duct side since 2010 when the ability to slope pipe came out. All Autodesk has to do is add a parameter to its fitting connectors. It is just that simple, and I am sure it is one of you could do in less than a week or two.
All you have have to do is when a pipe or duct fitting is created, assign it one of 4 connector type parameters, and that can pretty much cover almost every type of end connection out there.
Generic: an end to end connection for generic fittings, no change required (would change nothing inside of Revit)
Socket: For connections Round & Oval duct, PVC, Copper, Pex, Brazed, etc.... (No Routing Preferences changes needed in other words would change nothing inside of Revit)
Joined or Coupled: For slip & drive duct connections, gapped welded connections, grooved, no hub, etc.. (A minor change to the routing preferences to allow for a coupling to be inserted as these fittings are used).
Flanged: for all flange to flange connections already in the routing preferences.
Additionally, I would recommend adding a text parameter called "End Condition" to the connector element. For when a pipe/duct is attached to a fitting, the end connection parameter will be transferred to the pipe/duct, so when it's scheduled, the end-user will know its end condition.
In closing, I would like to say contractor companies like us and manufacturing companies like Victaulic and Gruvlok have been creating spool drawings from Revit using families for years now. By using groove coupling as flanges in the current way, Revit routing preferences are set up now. But by making this minor change, it could go a long way in making our work much more comfortable, and I know that's Autodesk's end goal is customer satisfaction.
Product and Feature: Revit MEP - MEP Mechanical Routing Solutions - (Mechanical
Submitted By: cbowker731182 on 11/07/2019
- You may not post replies
- You may not edit your posts
Forum Rules
