Thread: text strings
    2004-06
    Slidell, Louisiana
    816
    Default text strings
    i am trying to get the text label to be multiline. below is the expression i am using.
    however, it is not making it multiline. what i am getting is this: #28 Area#04.
    Concat ('#',Autoincrem , ' \n ' , 'Area#', Area01)
    what am i doing wrong. it says the expression is validated.
    thanks
    Robert
    5,737
    Default Re: text strings
    In the style label dialog, click on Advanced and you will see Label Position radio buttons. The default is Repeat. Change it to Fixed Location. You may also need to use \P instead of \n.
    2004-06
    Slidell, Louisiana
    816
    I'm using Map3D inside Civil 3d. my only options there are "next to feature or on top of feature with an x, y offset".
    unless im looking in the wrong place
    Robert
    5,737
    Does this help?
    2004-06
    Slidell, Louisiana
    816
    Attached is what mine looks like. I am not using Map 3d, i am using the map3d functionality inside civil 3d if that matters any.
    Robert
  1. Replies: 7
    Last Post: 2006-10-21, 03:02 PM
  2. Text strings in Dimensions
    By DaveP in forum Revit Architecture - Wish List
    Last Post: 2006-06-26, 12:34 AM
  3. Match text strings by selecting
    By spaynter in forum AutoLISP
    Last Post: 2005-10-12, 08:32 PM
  4. formating text strings
    By rwbaker in forum VBA/COM Interop
    Last Post: 2005-09-20, 06:02 PM
  5. Breaking long strings of text data in Annotations
    By JeremiahM in forum AutoCAD Map 3D - General
    Last Post: 2005-05-04, 02:27 PM
