Thread: When to start saving to 2018 file formet?
    2018-02
    2
    Default When to start saving to 2018 file formet?
    I have always saved files down to the previous file format. When the format changed in 2018, I still saved in 2013 format. Since moving to 2020, my pipe drawings, both my models and files I data ref them into will not save down to 2013. What's funny is that I can open the dwg in 2018 and save it to 2013 format. I have no issue saving in 2018 format, but I share files with other consultants and they may not be running 2018 or newer yet.
    So for best practices, when do people normally move to the latest dwg format?
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL
    3,362
    Default Re: When to start saving to 2018 file formet?
    You're probably using a vertical to create those pipe drawings that include either intelligent objects included in 2020. Since it's base is still 2018 you're able to open it in 2018 and save it down, but you're dumbing down the drawing. Save those dumbed down versions with 2013 as a suffix for those who need it, but I'm always going to save my drawings in the format created for the version I'm working in.
    Tom Beauford P.S.M. - Civil 2020 on Windows 10 Enterprise
    Design Analysis - Leon County Public Works/Engineering Wrap [CODE] tags around selected text
    Ph# (850)606-1516 Home Page
  1. 2018: inventor 2018 File Export Options
    By Trevelyn.Blazzard in forum Inventor - General
    Last Post: 2018-07-24, 02:28 PM
  2. Quadro M1200 for Autocad 2018 and Revit 2018
    By fredrik.schlau in forum Hardware
    Last Post: 2018-03-19, 09:09 PM
  3. 2016: Backwards saving a drawing from 2018
    By Damian_E in forum AutoCAD General
    Last Post: 2017-09-15, 12:22 PM
  4. 2018: SAVING DOWN 2018 FILES TO 2017 OR OTHER VERSIONS OF AUTOCAD
    By PINESTONE CADGUY in forum AutoCAD Civil 3D - General
    Last Post: 2017-08-07, 02:26 PM
  5. Replies: 0
    Last Post: 2013-05-06, 01:30 AM
