Thread: Blocks with different visibility states
    2009-11
    Raleigh, NC
    944
    Default Blocks with different visibility states
    2 questions,
    1) Are blocks with different visibility states called "dynamic"?
    2) How do you draw an object and assign it to all visibility states?
    2015-10
    Central New Jersey
    439
    Default Re: Blocks with different visibility states
    1) Yes, visibility states are just one of the available parameters in a dynamic block.
    2) In the block editor select the objects within a block with visibility states and choose Object Visibility from the right clock menu. You'll see 4 possible selections for visibility.
  1. Replies: 13
    Last Post: 2024-03-16, 12:26 AM
  2. Mutiple Grips for Same Action under different Visibility States
    Last Post: 2018-02-20, 02:21 PM
  3. Layer States to Visibility States?
    By Ant59 in forum AutoCAD General
    Last Post: 2009-07-07, 11:17 AM
  4. Dynamic blocks, Visibility states, Attributes
    By megumby in forum Dynamic Blocks - Technical
    Last Post: 2007-08-03, 05:06 AM
  5. Replies: 9
    Last Post: 2007-03-15, 07:34 PM
