Thread: Storm Top Surface Issue
    2015-11
    Indiana
    49
    Default Storm Top Surface Issue
    When data referencing a storm system into the cross sections, the below image is a common error in our drawing files. The correct surface is set in the data file and the data ref. has the correct surface in the properties dialog for the structure.
    Simple to fix, just have to go into structure properties reselect "Reference Surface" and choose the same surface that it is already referencing.
    But why do we have to re-select the surface that it is already referencing? This happens every time it re-syncs as well. So in order to plot a set of cross sections you have to re-select the reference surface for all manholes.
    Any suggestions?
    2009-11
    5,714
    Default Re: Storm Top Surface Issue
    What happens when you manually sync the Pipe Network (after opening the drawing)?
    What is the new PIPENETWORKSYNCMODE sysvar value?
    Computer Specs:
  1. Replies: 0
    Last Post: 2015-08-07, 05:24 PM
  2. Titleblock - issue date and type of issue placed in issue column
    By jdrexler in forum CAD Management - General
    Last Post: 2006-04-10, 05:01 PM
  3. Storm shutter (steel framed opening)
    By Adam Mac in forum Revit Architecture - Families
    Last Post: 2005-11-02, 05:54 AM
  4. Storm Water Detention Design
    By dlampley.41310 in forum AutoCAD Civil 3D - General
    Last Post: 2005-10-12, 06:33 PM
