Results 1 to 8 of 8
Thread: Linked Excel Spreadsheet shows in plot preview but will not plot to pdf
    2018-04
    VOLS FAN STUCK IN NOTRE DAME
    30
    Default Linked Excel Spreadsheet shows in plot preview but will not plot to pdf
    I just had a linked excel spreadsheet in AutoCAD show up in plot preview but when the pdf was made it just wouldn't print. I tried every suggestion I could find in forums and nothing worked. Turns out the excel files extension was the problem. I was inserting from a .xls file and when we switched the extension to .xlsx it plotted. Hope this can help someone else if they come across this problem.
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    Default Re: Linked Excel Spreadsheet shows in plot preview but will not plot to pdf
    2014-08
    447
    And Why Not use it all the time works great, don't fix what's not broke
    2001-03
    Tallahassee, FL USA
    3,667
    Quote Originally Posted by remi678731 View Post
    About 263,000 results from a quick Google search of "AutoCAD OLE not printing" say you're wrong: https://www.google.com/search?newwin...R_yCFQQ4dUDCAs
    as well as the thread you just posted to that said it wasn't working.
    2014-08
    447
    Again it works fine on my.
    What is the problem on other machines I'm not sure but I'm not fixing what works here. It might have something to the size or complexity of the OLE
    2001-03
    Tallahassee, FL USA
    3,667
    Many reasons, but often it's simply because since they're not AutoCAD objects they don't rotate with drawing viewports: https://knowledge.autodesk.com/suppo...E-objects.html
    If you're doing simple enough drawings that it works for you great! Do what works for you.
    When a thread is started because a user is having an issue "Works great for me" isn't a very helpful response.
    2009-07
    2014-08
    447
    Why would you put in model space
  1. 2015: Subassembly - Works but nothing shows in preview box!
    By jh_dempsey in forum AutoCAD Civil 3D - Corridors
    Last Post: 2016-08-25, 01:30 PM
  2. Crop Region shows on sheet in model, but not print preview
    By Denis01 in forum Revit Architecture - General
    Last Post: 2009-03-26, 03:57 PM
  3. Plot Preview is fine but plot is not
    By cadmecheng in forum AutoCAD Plotting
    Last Post: 2006-07-26, 03:10 AM
  4. Replies: 2
    Last Post: 2006-07-17, 11:42 AM
  5. Insert Excel spreadsheet only half shows up
    By dcochrane757156 in forum AutoCAD General
    Last Post: 2006-03-22, 11:40 PM
