can someone tell me what this means and how to fix it? i've run audit and recover numerous times, still is showing up
*Warning* Multiply owned object, handle "128B"
This means the the object with the handle "128B" has multiple owners. Each object should have just 1 owner. You can check what the object is with this line of lisp code:
I've found that these multiply owned objects are typically styles copied from other drawings and can be safely deleted using this lisp:Code:(entget (handent "128B"))
Code:(entdel (handent "128B"))
Thanks Jeff_M. not sure how to use the lisp though. Can you elaborate?
Just type it into the command line. The "128B" is what the warning message returned in the example you posted. Replace that with the handle returned anytime you get that Warning.
thanks guys.
