Thread: Geometry of closed-loop sweep and circular sweep won't join only when profiles align at 4 points
    2014-08
    2
    Default Geometry of closed-loop sweep and circular sweep won't join only when profiles align at 4 points
    I'm working on a window family where I'm using sweeps to create the stile/rail elements. While the window and casing are fairly custom, I nevertheless built in several parameters into the family to adjust height, width, arch depth, transom height, etc. as the design will change in the future.
    Here's the problem: The circular sweep in the transom can't join with the arched transom sweep of the same profile ONLY when the transom height and width are such that the profiles overlap exactly as shown in the attached screenshot. Then, of course, I get the "Can't join geometry" error message and the sweep gets deleted. Otherwise, when the window width is wider than the diameter of the circle, then the circle sweep joins correctly with the top and bottom rails of the transom sweep, and there aren't any problems.
    I understand most of the issues that arise with attempting to join geometry, but this one has me a bit puzzled. I'm sure it probably has to do with the profile of the circular sweep being exactly aligned with and contained in the the same profile of the arched transom sweep in this condition.
    Possible workarounds or fixes? Any help or clarification would be appreciated.
    Scot
    2010-10
    Chicago, IL
    376
    Default Re: Geometry of closed-loop sweep and circular sweep won't join only when profiles align at 4 points
    Isolate in view the circular sweep and two center ref planes. Move center of the sweep path (make sure you snap to center - SC) to the intersection of two ref planes (SI).
    Revit file attached.
    2014-08
    2
    You, sir, are a scholar and a gentleman! Thanks very much.
    Now, why that works and why what I had wasn't working I've still no idea ... but so it goes with Revit oft times!
    2010-10
    Chicago, IL
    376
    Indeed you had the center of the sweep at the ref planes intersection, but it was not constrained to it.
  1. Be able to have a closed loop after a circular sketch pattern
    Last Post: 2012-08-31, 03:40 AM
  2. Align and Join Geometry
    By mwagenbach in forum Revit Architecture - General
    Last Post: 2006-05-19, 08:25 PM
  3. sweep with circular profile wont align?
    By Justin Marchiel in forum Revit Architecture - General
    Last Post: 2006-05-17, 11:59 PM
  4. Closed Loop Profiles
    By jstorms1818 in forum Revit Architecture - Families
    Last Post: 2003-11-06, 02:53 PM
Tags for this Thread
