Hello. Here's a spline question that is puzzling me. Using the spline command, when finished, hit enter and the command is over. When I tried using it in a lisp I have to hit enter 3 times...once to end creating the spline and once on each end of the spline.
Back story is a coworker likes to use the spline command for when we draw cables to get his layout. He then uses splinedit, then pedit so he can give it a thickness. So I made an attempt to create this for him to save him some steps. This works, but like I mentioned in the beginning, I'm asked to hit enter on each side of the spline. This happens to me even if my lisp only consisted of (command "spline").
(setq SC (getvar "DIMSCALE"))
(setq CABTHK (/ 0.05 (/ 1 SC)))
(command ".-LAYER" "m" "CABLES" "c" "82" "CABLES" "lt" "continuous" "CABLES" "")
(command ".spline")
(while (> (getvar 'cmdactive) 0) (command pause))
(command ".splinedit" "L" "P" "")
(command ".pedit" "L" "W" CABTHK "")
(princ)
Any thoughts? Thanks,
Paul
