Results 1 to 9 of 9
Thread: Strange red circle symbol at 0,0,0
    2012-11
    15
    Question Strange red circle symbol at 0,0,0
    We received a drawing from our client and it has a little red circle on 0,0. You cant select it. Turned off and froze all layers and its still there so it's not on a layer. It's in model space. If you x-ref the drawing into a sheet the circle does not come with it. It does not show if you try printing that area.
    If you orbit the drawing into a 3-D view it's actually an arrow pointing straight down at 0,0 in the Z-Axis. If you zoom in or out it always stays the same size. It appears to just be a visual mark that you cant do anything with.
    I attached a couple screen shots for reference.
    It doesn't seen to be causing an issue. Let me know if you have any idea what it is.
    Thanks!
    Rob Greenwald
    2005-06
    in the upper right corner
    3,507
    Default Re: Strange red circle symbol at 0,0,0
    possibly a civil drawing you received with "geomarkervisibilty = 1"?
    2001-03
    Tallahassee, FL USA
    3,667
    Setting GEOMARKERVISIBILITY to 0 should fix it.
    If you add this code to your acaddoc.lsp file you will never see it again.
    (if (/= (getvar 'geomarkervisibility) 0)(progn(setvar 'geomarkervisibility 0)(princ "\nGeomarkerVisibility turned off. GEOMARKERVISIBILITY")))
    Turlock, CA
    6,420
    Or you could add it to SYSVARMONITOR.
    C:> ED WORKING....
    LinkedIn
    2017-11
    California
    Definitely a Geolocation marker. It just means the drawing has a coordinate system associated to it. Usually used to underlay Bing Maps or a Mr Sids image below the site. If a Geolocation ribbon opens at the top of the screen, you can toggle realtime(ish) maps, or remove the location altogether. But the marker should not plot, or be visible in paperspace.
    I don't have Vanilla Autocad installed, or I'd test it, but setting mapstatusbar = show will add the geolocation info to the status bar at the bottom of the screen (Civil 3d). Likewise setting it to hide will make it go away. There you can see what coordinate system the drawing is set to.
    Earth
    9,805
    Why not just (setvar "geomarkervisibility" 0) ?
    I realize both are virtually instantaneous, but if you were modifying 100 or 1000 sysvars, it would certainly be quicker to simply change the status to the desired state rather than checking for the existing state first?
    Thanks.
    R.K. McSwain | CAD Panacea |
    2012-03
    I read somewhere that the red circle is there in case you want to move the origin point.
    Sometimes i can grab it, sometimes i can not.
    Just don't look at it too long...
    2001-03
    Tallahassee, FL USA
    3,667
    Thanks.
    Works either way. While it wouldn't be in one of my drawings I check the text window whenever I open a drawing from someone else to see notifications of what variables I've changed. If it's something that needs to be returned I've got a profile that doesn't run my ACADDOC.lsp file.
    2015-09
    2
    And you can set your template setvar to 0.
  1. Solid Red Circle Appears
    By ethan.thompson342869 in forum AutoCAD Civil 3D - General
    Last Post: 2012-11-26, 11:19 PM
  2. Red Circle Chasing cursor
    By Mufasa23 in forum AutoCAD Action Recorder
    Last Post: 2008-07-10, 05:16 PM
  3. Distance from circle to circle
    By Brian.164262 in forum AutoLISP
    Last Post: 2008-04-24, 05:31 PM
  4. red death circle when drag to sheet file
    By utakecare2003 in forum ACA General
    Last Post: 2007-10-28, 09:28 PM
  5. Circle Polyline (ie Circle with Width)
    By johan d in forum AutoCAD General
    Last Post: 2006-02-03, 11:16 PM
