Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: SHEET SET CREATION AND IMPORTATION
  1. #11
    100 Club gisdude's Avatar
    2005-10
    104
    Default Re: SHEET SET CREATION AND IMPORTATION
    @jtbworld - this looks promising. I'll give it a go on Monday. Thx.
  2. #12
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,103
    Quote Originally Posted by jimmy.bergmark View Post
    To make use of the Sheet Set Manager you need to have your title blocks in paper space.
    If you have to stay in model space use other methods like our JTB BatchAttEdit app to bulk edit attributes across many drawings.
    This is not completely true. One must have a layout associated with the drawing. The titleblock can still reside in modelspace. However, some features of the Sheet Set Manager may not work as intended, such as fields associated to sheet set manager properties. I think all that is really needed, would be a viewport to allow for viewing or plotting the content of the associated sheet.
  1. Sheet Set Manager can't open Sheet Set File
    By mikemck in forum AutoCAD General
    Last Post: 2010-11-15, 08:48 PM
  2. Create Sheet Lists and Total Sheet Count for Subsets in Sheet Set Manager
    Last Post: 2008-10-12, 06:30 PM
  3. Import Dwgs and Sheet Set info into another sheet set
    By jschultz in forum AutoCAD Sheet Set Manager
    Last Post: 2008-03-05, 01:41 AM
  4. Insert Outside Sheet Set into Master Sheet Set List
    Last Post: 2007-11-28, 12:19 PM
  5. Sheet Set Eerror message "Sheet Set File Is Not Valid"
    By acortes24 in forum AutoCAD Sheet Set Manager
    Last Post: 2006-01-06, 12:26 AM
