Results 1 to 10 of 12
Thread: SHEET SET CREATION AND IMPORTATION
    100 Club gisdude's Avatar
    2005-10
    104
    Default SHEET SET CREATION AND IMPORTATION
    Hi all,
    I'm a noob to SSM. I basically will need to update attributed title blocks in projects that go to the crews with the SAME DATE for all drawings in each project. So, the crew knows it's operating from the same job package. I've researched for LISP scripts and using LEE-MAC'S tutorials on .scr's. It seems the best bet is SHEET SETS.
    We have ALL OUR DRAWINGS IN MODEL SPACE. We don't use PS at all. That's the way it's been and forever will be. Having said that, I'm trying to create my initial Sheet Set and in the folder, I can only import 4 dwg's. It's bizarre, because it seems as though the "Create Sheet Set" dialog will import these 4 drawings because they are in PS. But I open them up and they are in MS.
    Any ideas here? I've tried opening them up and saving again in MS, but no go.
    Thx for any help.
    Default Re: SHEET SET CREATION AND IMPORTATION
    Do you have the title block in model space too?
    in the upper right corner
    3,503
    Pretty sure SSM (for sheets anyway) is meant for layouts.
    Someone should REALLY re-think the workflow at your office by keeping everything in MS.
    Layouts have been around since release "11" or "12" I believe, over 25 years ago, they save a lot of time and aggravation when it comes to plotting and sheet management.
    The only thing I can think of given your situation, is to create layouts in your drawings and move the TB's to PS at 1:1 (as intended) and put viewports in them to the MS content.
    Then you can link them to SSM and have the TB info filled in.
    We use a combination of xreffed TBs and attributes per-sheet with SSM for all projects.
    2005-10
    104
    @tedg,
    I believe the earliest .dwg files we have are from 1991. I usually run a .dwg count every year, and last year it was >7000. Life is too short. I'm just a humble CADSAPIEN. I will have to jury rig something.
    @jtbworld,
    yes, the TB is in MS.
    Thanks all,
    9,803
    As stated by others, SSM only works for layouts, not "sheets" in MS.
    6,379
    You could bring your dwgs up to date using ScriptPro. Write a scr that does what you need to one dwg, then batch it with ScriptPro.
    9,803
    Doesn't sounds like that is a option.
    Quote Originally Posted by gisdude
    6,379
    I thought he might be willing to try if he realized the situation isn't hopeless.
    To make use of the Sheet Set Manager you need to have your title blocks in paper space.
    If you have to stay in model space use other methods like our JTB BatchAttEdit app to bulk edit attributes across many drawings.
    2005-10
    104
    @jtbworld - this looks promising. I'll give it a go on Monday. Thx.
  1. Sheet Set Manager can't open Sheet Set File
    By mikemck in forum AutoCAD General
    Last Post: 2010-11-15, 08:48 PM
  2. Create Sheet Lists and Total Sheet Count for Subsets in Sheet Set Manager
    Last Post: 2008-10-12, 06:30 PM
  3. Import Dwgs and Sheet Set info into another sheet set
    By jschultz in forum AutoCAD Sheet Set Manager
    Last Post: 2008-03-05, 01:41 AM
  4. Insert Outside Sheet Set into Master Sheet Set List
    Last Post: 2007-11-28, 12:19 PM
  5. Sheet Set Eerror message "Sheet Set File Is Not Valid"
    By acortes24 in forum AutoCAD Sheet Set Manager
    Last Post: 2006-01-06, 12:26 AM
