Results 1 to 8 of 8
Thread: Revision Schedule - How to manipulate format, appearance?
    2005-06
    in the upper right corner
    3,229
    Default Revision Schedule - How to manipulate format, appearance?
    Hello there,
    Hoping someone out there knows how to get into the guts of what drives the text, space, alignment format of the actual revision data (vs the headers etc).
    I have a revision schedule on a sketch (TB), I didn't create it but seems to be set up ok.
    The revision text isn't centered and has lots of space around it, and it is creating issues.
    I can't find what controls this. I looked into all the formatting controls I have and the "text style" that it is using.
    I've tried fixed and variable height, doesn't help.
    Somehow I need to control what happens in the revision data cells, all I can see is what text style I can assign there.
    Thanks in advance.
    Ted
    ____________________________________________________________________ ________________
    Windows 10
    AutoCAD 2018 - REVIT 2019 - Inventor Professional 2017 (when I can)
    2001-12
    Irvine, CA
    7,544
    Default Re: Revision Schedule - How to manipulate format, appearance?
    It's the same feature set as a regular schedule except available in the family editor and titleblock families. To get the fields, Sorting/Group buttons > Select the revision schedule name in the Project Browser then look in the Properties Palette, you should see the buttons.
    2005-06
    3,229
    Quote Originally Posted by Steve_Stafford View Post
    Yes thanks Steve, I did find that.
    The only controls I seem to have is the "text style" for that data. I don't know how/where I can control the other properties. The title and headers yes, but the data, no.
    I can't find any settings for formatting that controls this.
    Ted
    Windows 10
    2001-12
    Irvine, CA
    7,544
    That is odd. Compare your settings against a stock template and titleblock for differences. The row height is derived from the font chosen and since we can assign a font from those we use for text and dimensions there might be something in the text style configuration.
    2005-06
    3,229
    Thanks Steve, that did help a bit. I wasn't the creator of the revision schedule that I was dealing with (not that I knew any better).
    There wasn't anything odd that I could find with the font being used and I tried assigning other fonts which didn't help.
    I did, however, create a new schedule and picked a different font, matched the other settings and properties and it works great now.
    There must have been something else screwing it up that I couldn't detect.
    Ted
    Windows 10
    2001-12
    Irvine, CA
    7,544
    Great, glad you got a solution.
    All AUGI, all the time Ning Zhou's Avatar
    2006-08
    632
    how to control gridline height? via textstyle is the only way?
    2005-06
    3,229
    Quote Originally Posted by Ning Zhou View Post
    Yes, that seemed to be what was controlling it.
    The properties of the text style was causing my issue and by changing it fixed it.
    That's all I know about this due to trail and error.
    Ted
    Windows 10
  1. Better control over cell appearance in revision schedule
    Last Post: 2015-03-06, 12:23 PM
  2. 2014: Revision Schedule, Triangle (graphic) shows only if revision is present in titleblock
    By boyd.johnson679667 in forum Revit Architecture - Families
    Last Post: 2014-11-12, 06:13 PM
  3. How do I delete a revision from the revision schedule?
    By Blakester122 in forum Revit MEP - General
    Last Post: 2009-10-20, 02:24 PM
  4. Revision Delta in Revision Schedule.
    By doh in forum Revit Architecture - General
    Last Post: 2009-08-13, 06:19 PM
  5. Revision schedule format
    By whotch in forum Revit Architecture - General
    Last Post: 2007-07-11, 07:22 PM
Tags for this Thread
