Thread: Output Surface text and Alignment text and tick only to another drawing file
    2019-09
    Default Output Surface text and Alignment text and tick only to another drawing file
    Hi All,
    Our current drafting process is we keep our design drawing file and our production drawing files separate. Obviously when we try to copy out the surface labels or the alignment labels and ticks the civil 3d objects come with it. Our current work around is that we explode the labels twice, copy and paste to the production drawings and then back in the design drawing file click undo until the exploding procedure has been undone.
    My question is, is there an easier way to do this. Not a major issue but any help would be appreciated.
    Active Member dotson's Avatar
    2005-01
    56
    Default Re: Output Surface text and Alignment text and tick only to another drawing file
    Not necessarily easier but there are third party add-ons that let you export contour labels, surface elevation labels, and slope labels to a file that can then be imported back into other drawings at any time.
    2014-08
    448
    Hi
    try exporting a dwg backwards all civil3d objects get exploded and retain location
  1. Replies: 4
    Last Post: 2013-11-17, 09:49 PM
  2. Alignment minor tick mark
    By curtwhite10034 in forum AutoCAD Civil 3D - General
    Last Post: 2010-06-04, 11:48 PM
  3. Alignment Station and Curve Report - Output AZIMUTH?
    By kevin.jackman in forum AutoCAD Civil 3D - General
    Last Post: 2010-04-01, 02:51 PM
  4. Replies: 3
    Last Post: 2007-07-18, 12:35 PM
  5. Replies: 6
    Last Post: 2007-04-13, 09:38 PM
