Isn't this enough - without GrSnap...
(With your version - ACAD will snap to vertex of block itself if it's nearer insertion point before attempt to snap to other entity/ies in active space causing that insert while (entmod) moves with gaps - not smoothly)... This although insert do not snap, marker is turned on like with ordinary move with turned OSNAPS and insert is placed on marker upon finishing of routine...
(defun blkins ( blkname / BlkSetExplodability )
(defun BlkSetExplodability ( BlockName Explodability / e ed e330 e330d )
;second argument 0=non-Explodability 1=Explodability
(setq e (tblobjname "BLOCK" BlockName)
ed (entget e)
e330 (cdr (assoc 330 ed))
e330d (entget e330)
e330d (subst (cons 280 Explodability) (assoc 280 e330d) e330d)
);setq
(entmod e330d)
(BlkSetExplodability blkname 1)
(vl-cmdf "_.-INSERT" blkname "\\" 1.0 "" 0.0)
(vl-cmdf "_.EXPLODE" "_L")
(vl-cmdf "_.COPYBASE" "_non" (getvar 'lastpoint) "_P" "")
(vl-cmdf "_.ERASE" "_P" "")
(vl-cmdf "_.PASTEBLOCK" "_non" (getvar 'lastpoint))
(vl-cmdf "_.-RENAME" "_BLOCK" (cdr (assoc 2 (entget (entlast)))) (strcat blkname "-" (rtos (getvar 'cdate) 2 6)))
(princ)
