Results 1 to 1 of 1
Thread: Steel Beam and Pipe Flanges and Fittings
    2011-10
    Norfolk England
    57
    Default Steel Beam and Pipe Flanges and Fittings
    Hi
    This may not be the place for this as its VB based but I think its easier than the blocks route.
    Although the VB does produce a block as an insertion.
    Its handy if you are doing 3D, just explode the block and, in the case of Steel Section, use the polyline outline to stretch to 3D, and use the Flange as solid of rotation.
    Make sure you have the VB module loaded!
    Hope this helps somebody
    Cheers Geoff
    See also VB Programming
    I have added an AISC Steel zip for the American audience
  1. Pipe Flanges defined at the connector, not in the Pipe type
    By Wish List System in forum Revit MEP - Wish List
    Last Post: 2016-08-05, 02:41 PM
  2. Replies: 3
    Last Post: 2015-12-05, 08:19 PM
  3. Revit pipe flanges and flanged valves
    By tim99 in forum Revit MEP - General
    Last Post: 2015-06-25, 11:17 AM
  4. Pipe and fittings w/flanges
    By SRBalliet in forum Dynamic Blocks - Sharing
    Last Post: 2011-05-08, 10:38 PM
  5. Beam Flanges over 2'-0" width not responding to Framing Elevation.
    By dlevesque in forum Revit Structure - General
    Last Post: 2007-06-19, 03:15 PM
