Results 1 to 1 of 1
Thread: Steel Beam and Pipe Flanges and Fittings
    2011-10
    Norfolk England
    57
    Default Steel Beam and Pipe Flanges and Fittings
    Hi
    Here are a couple of vb programs for inserting blocks of various beam sections and pipe fittings into a drawing file.
    I created these for my own use and have found them quite handy, I am now retired and only use Acad occasionally, so am sharing the fruits of my labours, warts and all, with any one who cares to make use of them.
    They are in mm units, if imperial units are required the .dat files, in the 'acad/vba/datafiles' folder will need to be modified.
    Not a difficult task although time consuming. (perhaps I'll look into it as a project)
    Have reattched the Steel.zip and included a fix for Imperial sizes of American Steel sections only ........ 17/12/20
    Have also posted this in the Dynamic Blocks shared area as I feel these are easier to use than a block library.
    Also posted on the 'Swamp' a few years ago user name Calteq
    Enjoy .......
    19-9-2023
    Have now added an AISC for the American audience
    A Check would be welcome
    It would be nice for some feed back THX
    Another update cuix files now contain ribbon features
    Last edited by Calteq; 2023-09-21 at 07:44 AM. Reason: Have attached an Aisc Section zip
  1. Steel Beam and Pipe Flanges and Fittings
    By Calteq in forum Dynamic Blocks - Sharing
    Last Post: 2020-02-11, 01:05 PM
  2. Pipe Flanges defined at the connector, not in the Pipe type
    By Wish List System in forum Revit MEP - Wish List
    Last Post: 2016-08-05, 02:41 PM
  3. Replies: 3
    Last Post: 2015-12-05, 08:19 PM
  4. Revit pipe flanges and flanged valves
    By tim99 in forum Revit MEP - General
    Last Post: 2015-06-25, 11:17 AM
  5. Pipe and fittings w/flanges
    By SRBalliet in forum Dynamic Blocks - Sharing
    Last Post: 2011-05-08, 10:38 PM
