In place walls with layers
Summary: The ability to create in place walls with layers as per standard wall types
Description: At the moment when creating an in place wall, it is just an extrusion with a single layer. The ability to assign layers like the standard wall type is needed. Also functionality of the wall and how it deals with demolition and hosting families needs to be worked on.
Trying to model an existing building which has 40 or so wall thicknesses is a pain. If the option of adding Modify Sub Elements like in flat roofs was added, this would make creating skewed walls much easier.
Product and Feature: Revit Architecture - Walls
Submitted By: metallied449721 on 02/18/2020
- You may not post replies
- You may not edit your posts
Forum Rules
