Results 1 to 1 of 1
Thread: Blocks plot with black background
    2018-03
    Default Blocks plot with black background
    Hope you can help
    When printing an AutoCAD drawing to a pdf file (DWG To PDF pc3) using Paper Space the print comes out with black background (see attached) around the blocks (trees).
    If I print once again to a pdf in Model Space using the same drawing if prints as required (without a black ground).
    Any ideas would be appreciated
    Clive
  1. 2013: Arial Black font looks black italic
    By sven.129574 in forum AutoCAD General
    Last Post: 2014-03-06, 01:49 PM
  2. Dimension background plotting black
    By aaronw.90632 in forum AutoCAD General
    Last Post: 2006-09-01, 03:11 PM
  3. Plot Preview Background is Black not White
    By cadmecheng in forum AutoCAD Plotting
    Last Post: 2006-01-24, 09:55 PM
  4. Plot White Text on a Black background
    By kathy71046 in forum AutoCAD Plotting
    Last Post: 2005-12-16, 11:00 AM
  5. Plotting with a black Background?
    By brian.deuchar in forum AutoCAD Plotting
    Last Post: 2004-12-02, 10:19 AM
